Lack of Sharpness
Posted 08/10/2012 - 16:53 Link
Hi - I own a Pentax Kr
Great camera but I just can't seem to get sharpness when taking pictures. I understand DOF etc so I'm happy it's not that. I'm using the 18 - 50 Lens that came with the kit, is it possible that this is the problem?
snappychappy
Posted 08/10/2012 - 16:58 Link
Hi and welcome to the forums. Can you post some examples? What settings are you using for the shots and what type of photos, landscape portrait or sport ect.
Vuillaume
Posted 08/10/2012 - 20:19 Link
Hi, welcome. Are you shooting in RAW? Did you try to mount the camera on a tripod (no SR)?
John
PPG link
Edited by Vuillaume: 08/10/2012 - 20:42
DaveHolmes
Posted 08/10/2012 - 21:04 Link
Examples (pictures) with exif would be helpful in diognosis...
What shutterspeeds are you shooting at?
Digital:
Flash:
Film:
davidstorm
Posted 08/10/2012 - 22:03 Link
I would think it very unlikely that the lens is the cause of the issue you are describing. It is possible the autofocus is not correctly adjusted (this afflicted my first K-x very badly and it back-focussed all the time until I found out how to adjust it in the Debug Menu).
I don't know how old your camera is, but I would get it checked. As the other guys have said it would be useful for you to post some images with details of the settings and how you shot them.
Charlotte
Posted 08/10/2012 - 22:17 Link
When I first started using my k-r all my photos were soft - I found in the menu a sharpness adjustment which I set to sharp and that solved the problem.
I'm afraid I can't remember which menu it was in and I can't check because I can't access anything on my k-r.
Pentaxophile
Posted 09/10/2012 - 11:34 Link
We really need to know what aperture and shutter speed you are using, and how you are viewing the images (windows image viewer, for example, is terrible for viewing high resolution images and will appear soft until you zoom in to a 100% view and then back out again)...
McGregNi
Posted 09/10/2012 - 17:56 Link
Try opening your shots with this viewer program (after converting from RAW). link This Fullscreen Photo Viewer is very quick and displays images in high quality and nicely sharp.
When converting from RAW you could apply a little sharpness to make sure it is not just inherent softness.
MikeyJay
Posted 12/10/2012 - 20:09 Link
Try switching from auto focus and using the manual focus ring on the lens. If your focus confirm icon comes on in the viewfinder, try taking a picture.
If the results are STILL blurred, I strongly recommend you get it looked at ASAP.
It's not about the equipment; it's the results you achieve with it.
