Kx view finder
petermichael
Posted 29/12/2010 - 08:12 Link
I have just purchased a Kx and have problems looking through the viewfinder with my glasses on, I am very short sighted and can not manage with them off. does anyone have the same problem or sugestions on how to overcome this.
Posted 29/12/2010 - 08:57 - Helpful Comment Link
Welcome, I've moved your question to a section where it will gain more attention.
I would make sure the dioptre adjustment is correct in the viewfinder. Point the camera at a blank surface, wall or sky perhaps, and adjust the slider until the etched lines in the viewfinder are sharpest. You are now focused on the screen itself and the view through the finder should be fine.
Otherwise, I too am very shortsighted and use glasses with my cameras and I don't have any particular problem. Press the viewfinder tight against the glasses so as much as possible of the screen can be seen at one time.
flossie
Posted 29/12/2010 - 08:58 Link
Hi.... what sort of problems are you having with your glasses?
If it is out of focus / blurred, there is a little adjustment lever above the viewfinder (diopter) which you can slide about.
If you can't see the image fully, because the glasses are pushing you back, you could try shooting with LiveView (LV button on the back) instead?
just a couple of initial thoughts...
petermichael
Posted 29/12/2010 - 09:31 Link
Thank you for your help my problem was seeing all the info in the view finder
flossie
Posted 29/12/2010 - 10:02 Link
Oh, the little numbers at the bottom telling you what settings you have? Sorry, I can't help much there - I can't read them either most of the time...
techno-terminator
Posted 29/12/2010 - 10:51 Link
I've the same problem my glasses are not just varifocal they are light sensitive as well and the combination makes me really careful .
I find that keeping my head still while looking in the viewfinder and then just letting my eye look down slightly so-to-speak usually brings the wee row of icons into view.
Make sure you do not turn the bleep confirming focus off . If I'm in bright light I frequestly can't see the green hexagon confirming focus but I can hear the bleep
let the education continue
Blincodave
Posted 29/12/2010 - 11:28 Link
If it is not a diopter adjustment problem then the camera is not giving you enough eye-relief ie you cannot get your glasses close enough to the viewfinder. It is a common problem for glass wearers; I too have the same problem. The K-x actually offers relatively good eye-relief - try looking through an Olympus 450/620 or some of the Sony DSLRS and you will see they are worse.
Dave
petermichael
Posted 29/12/2010 - 19:37 Link
Thanks to everyone for there help it has been very usefull Listen for the sound forgot to tell you I am deaf as well, but then again i am over 70. But I will master it. this is my first DSLR so a complete newbie as I am with this forum Not Much hope Deaf short sighted and new
Blincodave
Posted 29/12/2010 - 20:00 Link
Good luck PM, I'm sure you will be very pleased with your K-x
Dave
