kr mount
Posted 05/02/2009 - 15:46
Remove the pin first. Otherwise it will get caught in the AF hole. It is then a matter of nerve to twist back off. Here is the pin that needs to be removed. I just use a dremel.
[IMG]http://i54.photobucket.com/albums/g109/greyhoundman/KR-PIN.jpg[/IMG]
Posted 05/02/2009 - 18:18
If the lens is not AF, then it won't AF... I actually don't recall Ricoh having a pukka AF camera so I wouldn't expect a KR mount lens to have AF capabilities.....
Z-1p, K-1, P50
Posted 05/02/2009 - 18:33
It won't autofocus. But if the pin is left on, it will get stuck on the 20D.
Posted 05/02/2009 - 18:38
you can take out the pin by removing the four screws shown above and pull the pin out with a pair of tweezers
Barrie - Too Old To Die Young
Posted 05/02/2009 - 19:25
hi is it easy to remove taking the screws out.
just keep snapping,
nikon d300 + battery grip.
sigma 150-500mm apo dg hsm os
sigma 170-500mm apo dg
Posted 05/02/2009 - 19:39
It should be, but be VERY careful.
From past experience the contacts are spring loaded and are easy to lose when you lift the mount off.
Cheers, HG
PPG entries.
PPG entries.
Posted 05/02/2009 - 19:43
I did not have much trouble. i've done two Vivitars, Series1 28-105 and 70-210 also a Sigma 400m f5.6 and they still work.
These all had small spring retainers holding the pin in. It was just a case of pulling the pin out against the retainer. Then be sure you line up aperture linkage when you reassemble.
In the lenses i've done removing the mount did not open up the optics and there was no problem reseating the mount.
Posted 05/02/2009 - 19:54
Go to the Ebay reviews section, search for KR Mount. Someone has done a blow-by-blow tutorial with photos on how to do it. I've done three Ricoh 50mm lenses for a work colleague and it was quite easy. Just have a well-lit place to sit and work, a couple of lens caps for the screw, and some time without being disturbed. The second one you'll do with your eyes closed*
*not literally, please don't close your eyes
Posted 05/02/2009 - 20:34
cheers guys, anyone know much about the lens, a sirius 60-300mm
just keep snapping,
Posted 05/02/2009 - 20:39
Don't have a true Macro so these are from the Vivitar 28-105 of the 70-210. Had to take it apart anyway trying to fix the aperture ring lock.
[IMG]http://i679.photobucket.com/albums/vv154/bforbes/IMGP1056.jpg[/IMG]
[IMG]http://i679.photobucket.com/albums/vv154/bforbes/IMGP1057.jpg[/IMG]
First shows lens with mount removed. In the centre of two you can just see the hole and retainer that held the pin.
hope it helps.
hope it helps.
Posted 05/02/2009 - 20:42
cheers bf, looks simple enough. might give the lens ago its just knowing how good it is,
just keep snapping,
Posted 05/02/2009 - 23:15
What mount does this conversion leave you with? K or KA?
Posted 05/02/2009 - 23:21
KA - you are only taking out an extra contact that is used by Ricoh Cameras. The Pentax contacts are left in tack.
Posted 05/02/2009 - 23:22
cheers bf.
just keep snapping,
devon (honiton)
lens is a sirius 60-300mm
