KR fine focus adjustment.
Posted 14/09/2011 - 15:27
http://www.pentax.jp/english/support/download_manual.html for the manual
Menu C page three item 21. Only one global setting on KR though.
Did you turn the shake reduction off (info screen push two top right) as it won't work on a tripod?
Posted 14/09/2011 - 16:19
There are some calibration installations you can make or buy where you need to focus on and fine tune the focus.
You can simply test the focus with a tripod by first making a shot with the normal AF and then one using the liveview contrast focus, that one bypass all the calibration errors that can occur with the normal AF.
If you see a difference then the AF might be out.
Posted 14/09/2011 - 16:27
simonjames wrote:
Hi all,
I was taking some test shots with my new Sigma 50mm Macro (on a tripod)at various apertures, and whilst they were high quality I'm convinced they could be sharper (or maybe its just me), and as I didn't get a user guide with my used KR, what is best procedure for 'tuning' in lenses using the fine focus adjustment facility?
I'm assuming what you're looking for is advice on the best procedure, set-up, etc?Hi all,
Rather than repeat other posts, if you search for AF tuning here on the Forum it will throw up a few discussions and pointers, as this has been a much aired issue.
If you don't find what you want, PM me, and I'll forward you a number of (non Forum) links on the subject.
