K7 Raw files and Photoshop CS3
Posted 09/01/2010 - 21:08
I got round it by shooting as raw dng in camera then i dont need to convert them but of course that does not help the ones you have allready taken
hopefully the pink tinge can easily be removed
K7D DA 18-55 mk11WR|50-200 wr|DA16-45|Tamron SP90|lots of manual pentax glass
Posted 09/01/2010 - 21:21
Thanks for the comment Will, I am going to give this a go tomorrow. But in the meantime I will have to some serious post processing.
Graham
Graham
Posted 10/01/2010 - 00:15
Not an expert but I don't think this is a conversion issue but an attempt somewhere (either by the camera or CS3) to 'correct' the white balance on the image.
Do you have any other software with which you can open the image? Are all the images coming out the same?
Posted 10/01/2010 - 09:53
I suspect you are right regarding the white balance issue, the pink exists on all shots and is more pronounced on night shots due to the addition of artificial light on the snow. I have now set my K7 to "DNG" and "Adobe RGB colour space" to see what the effect is. Not an expert but I don't think this is a conversion issue but an attempt somewhere (either by the camera or CS3) to 'correct' the white balance on the image.
Any other changes I should know about?
Thanks Gareth
Posted 10/01/2010 - 12:03
The colour space wouldn't do a thing since RAW don't have one
If you don't mind beta software why not use Lightroom 3 beta?
http://labs.adobe.com/technologies/lightroom3/
You can use it till April 30
The nice thing is you can easily batch process so the colour shift can be sorted out in matters off seconds in all your photos.
Posted 10/01/2010 - 16:34
Thanks Stefan, I will have a play around with Lightroom. Upgrading to CS4 will be a little steep for me, so I may have to shop around for a more economical solution.
Regards Graham
Regards Graham
Posted 10/01/2010 - 16:41
You can keep photoshop CS3 if you shoot in DNG, another solution would be is to get a rawconverter like Silkypix, lightroom, phaseone, etc.
Those are cheaper and enables you to do what you need to get a good finished photo and you can keep CS3 for the special/creative imaging stuff.
I myself use Lightroom 2 with CS4 and those two work very well together, with one command you can open the file from lightroom in photoshop and do your thing there, surely if you convert the RAW file to DNG it works splendidly in photoshop, it's like using a PSD file, you don't need to convert your file to PSD or TIFF like you would sometimes with PEF if you do HDR stacking for example.
Posted 10/01/2010 - 17:06
I just shoot in dng and use cs2 with the colour space set to adobe rgb if i add jpeg as well and get no issues so hopefully you will be fine
Posted 10/01/2010 - 19:23
I had hoped to stay with the Pentax PEF file format, just for the sake of consistency rather than any other reason. It does worry me that old file formats can become totally obsolete, not a problem in the days of film photography, but a pain if you have to go through the whole back catalogue and convert them to keep up with the times.I remember seeing a program about the national document archive and how they were experiencing problems keeping the integrity of documents, not just the text contend but the look and feel. Even with Microsoft word they had to have each version from 1.0 to the current day and ensure that the original fonts version were available. I just shoot in dng and use cs2 with the colour space set to adobe rgb if i add jpeg as well and get no issues so hopefully you will be fine
Regards Graham
Posted 11/01/2010 - 19:34
I agree - thats why adobe brought out the pubicly available dng format to try to addresss the problems of long term archival format. Pentax have taken the enlightened route of making it available in camera along with Hasselblad, Leica, Casio, Ricoh, and Samsung
Posted 12/01/2010 - 13:14
Yep I've found this problem when I upgraded from K10 to the K7. Took some photos on RAW PEF then when I uploaded on the PC, when I first viewed them through Picasa 3 the photos would get a pink tinge to them. Then when I tried to load up the photos through Camera Raw option on Elements 7 a message popped up saying unable to load as file is wrong type. I've now changed my Raw settings from PEF to DNG and it works fine now.
K5mk.IIs with 17-70mm DA and Sigma 70-300mm DA lenses. Before digital I used the P30T when using Fujichrome Velvia.
Posted 12/01/2010 - 13:49
Adobe are a "PAIN".
They will not provide plugins for older software but force you to upgrade.
I had the same problem when moving from *istD to K20D. PEF file format is slightly altered and I was stymied. Either work in DNG or buy a software update.
Posted 12/01/2010 - 14:26
polchraine wrote:
Adobe are a "PAIN".
I believe almost all programs do that or does the earlier versions of silkypix support the K7?
Adobe are a "PAIN".
Somewhere at the back of my mind
