K7 and flash synchro-speed
1/250 was mentioned was just a rumour going around.
With HSS (high shutter speed/sync) you can however sync past 1/180 but the flash need to support that since it's a special feature.
It come close to strobing the flash during the whole duration of the shutter movement.
SR can be left on, I never found it a problem with the K10D and never heard something about the other cameras. So it's safe to assume it's no problem with the K7 either.
It could be that sony calibrated it very critical to get the higher sync numbers, probably they took the number on which they knew the curtains aren't infront of the sensor.
Because the SR move the sensor it needs to have a bit more room so a less critical number must be chosen.
I think Pentax took the less critical one and took the time the shutter is open fully, so no relative to sensor size or placement so SR does not influence the sync speed.
I'm not a photocamera engineer but it does make for a logical explanation.
ps. in my previous post I was talking about the K7 explicitly, sorry that I wasn't clear about that.
Maisons Laffitte - France
