Flash choice for K7
Posted 17/01/2010 - 09:53 Link
I've significant birthday coming up, and was considering asking for a flash for my K7. I'm a complete novice with Flash & would welcome some guidance on what products would be suitable. Since I'm a novice I've no real idea of the application I'd use it for - so something that covers most of the bases would be good. Budget is around £200
Thanks in advance
K7, FA50 1.4, DA 16-50, DA 50-135, DA 2.8 35 Ltd DA 12-24
www.fotopedia.com/users/escaladieu
Pentaxophile
Posted 17/01/2010 - 11:43 Link
Samsung SEF-36PZF/Pentax AF360FGZ would be a great choice. (They're one and the same!) There's a Samsung one for sale in the Classified Section.
Anvh
Posted 17/01/2010 - 12:52 Link
Or the Metz 48 AF-1, it is a bit more powerful and it has a swivel head, but it has a crippled wireless-mode.
You can't use the flash to trigger another flash but that's it.
Here is a comparison between the flashes.
http://pttl.mattdm.org/ on the top in the black bar you can choice more options to see, flash-power, features, etc.
Stefan
K10D, K5
AF-540FGZ
Posted 17/01/2010 - 21:38 Link
AF-360FGZ, no other but better choices
K20D ,K10D, *ist DS, FA 50 f/1.4,F50 1.7,FA 28 f2.8, Tamron 17-50 f2.8, Tamron 90 f2.8, Tokina 28-70 f2.8,Sigma 70-200 HSM Macro II , DA*50-135 AF360FGZ, AF540FGZ
Edited by trungduongca: 17/01/2010 - 21:41
pentaxian450
Posted 18/01/2010 - 01:18 Link
I have three Sigma EF530DG Super. They work like a charm with the K-7 (and any other Pentax)
RobE17
Posted 18/01/2010 - 11:33 Link
I recently purchased a Metz 58 AF-1, a bit more expensive but capable of good results with the K-7. If you look at the boxing photos on my Flickr site they were taken with this combination:
Lafone Cup
Hope this helps,
Rob
golfdiesel
Posted 18/01/2010 - 11:51 Link
@gareth
The firmware update was for the 58 AF-1 in which they changed something in the way it triggers other flashes.
The 48 does not support the "master/control" function.
The 58 AF-1 has full wireless support and it has an 'A' mode which in the vast majority of situations works better then P-TTL mode.
The Metz units are built way better than the AF-360FGZ which has the most stupid design for the battery door which breaks easily.
Tamron Lenses: 28-200
Takumar Lenses: SMC 55 1.8
Anvh
Posted 18/01/2010 - 12:11 Link
Golfdiesel, there was also an update for the Metz48 but like you said it doesn't support master/control function.
This was updated:
Metz 48
1. Flash range indication enhanced.
2. Test flash with partial light input level.
Metz 58
1. Operation of second reflector enhanced.
2. Start signal in remote master mode changed from second reflector to main reflector.
3. Setting of the parameter values by repeat key.
Also the pentax AF360 & AF540 also have the "A" mode, it seems though P-TTL has been improved in the K-7, haven't tested it yet in the K-X.
My uncle has one so could try it tomorrow.
Stefan
K10D, K5
AF-540FGZ
