K7, K5, K3 - Sensor Shift Adjustment to get Lens Shift!
eddyc
Posted 10/10/2013 - 15:05 Link
amilner wrote:
Except the main reason the sensor can shift is to allow shake reduction to work - if the sensor were larger in the first place that would man you would need an even larger image circle if you wanted to retain sensor shift shake reduction.
And then you could have an EVEN bigger sensor...
And you end up with this:
eddyc
Posted 10/10/2013 - 16:03 Link
JAK wrote:
Not tried it but Microsoft ICE is said to be pretty good, and free!
http://research.microsoft.com/en-us/um/redmond/groups/ivm/ice/
Another free alternative from Serif:
http://www.serif.com/free-panoramic-photo-stitching-software/
There and many more.
I'll have a go with those tonight. Thanks!
I think I actually have a couple of panoramas that I never got round to stitching together.
JAK
Posted 10/10/2013 - 17:17 Link
You're missing the point. This is about getting a larger image from an APS-C sensor, not a larger sensor. When the camera is on a tripod one is supposed to deactivate the shake function so why not use it to capture a larger image based on the method shown in the videos the OP referred to? It can be done now, only it isn't automated but surely could be.
