K5iis Mirror partial reflex
Posted 09/07/2015 - 09:58
I would try a factory reset in the menus, updating to the latest firmware and using a new battery. Make sure the battery is OK first before doing any upgrades, just maybe it's reached the end of its life?
Posted 09/07/2015 - 10:44
Thanks John - I was already on V1.07. Tried the reset and fresh battery - no change but worth considering of course.
cheers
cheers
Posted 09/07/2015 - 10:48 - Helpful Comment
Cleaning lens and body mount contacts with a soft dry cloth is another possibility, just in case the contact has been partially lost.
Other than that, back to JPS for a repair quote i think. I would suggest joining Pentax User Plus first, then you can download the form from this site for a 20% discount on JPS servicing.
Posted 09/07/2015 - 11:37 - Helpful Comment
You could try the sensor cleaning mode if that fails it looks like you have a serious problem. My K10 failed a couple of months ago, you can hear the motor straining to lift the mirror in the above mode.
John
John
Posted 09/07/2015 - 23:16
What do you know...I tried sensor clean and it seems to have cleared it, at least for now. Here's hoping )
Posted 10/07/2015 - 00:06
4100 actuations
Is that number correct? Four thousand one hundred ?!?
4100 actuations
Posted 11/07/2015 - 23:49
Yes, 4100. Why do you ask?
http://www.pentaxphotogallery.com/artists/bre
cheers for any help
