K5 with macro lens
thoramay
Posted 13/11/2010 - 19:41 Link
Has anyone had experience of the K5 with the Pentax 100mm macro DFA 1:2.8.?
Does this camera limit use of the older lens.M, K, Ka etc.
regards Thoramay.
bforbes
Posted 13/11/2010 - 19:59 Link
As far as I can see, with the same provisos as earlier camera models/lens combinations, it is fully compatible.
Anvh
Posted 13/11/2010 - 20:18 Link
The K5 still use the same KAF2 mount what Pentax has used for 5 years or so now, I doubt there is any change in compatibility.
edit: crippled KAF2 mount that is.
Stefan
K10D, K5
AF-540FGZ
Edited by Anvh: 13/11/2010 - 20:19
Dave_Evanson
Posted 13/11/2010 - 22:02 Link
I haven’t used my 100mm macro DFA F2.8 with the K-5 yet, but the 35mm Limited macro works well and I don’t see the 100mm being a problem. I did try to grab some shots with one of my old K series lenses – a 400m F5.6 and the K-5 works fine. Just use the manual mode and the green button to meter (remember to cover the viewfinder if you are not using it when you meter).
Live view makes using these old lenses on a tripod much easier, especially with the electronic level enabled.
K-5 1/100 f8 at ISO1600 – SMC K 400mm F5.6
thoramay
Posted 14/11/2010 - 09:55 Link
The reason for asking is that I recall reading of isues with the change of mode in driving the zooms. I am aware that all lens will fit on the K5. Not so sure that all my older lens will function as such.
I am looking at upgrading to the K5 but I am attached to the older lens and want to be able to continue to use them.
I have viewed a chart that details how the various lens work on the K5 but no clear confirmation on th effect of the change of motors driving the zooms.
I have probably got it all wrong and my memory is playing tricks with me but Hey!! You kind members will put me right. What would I do without my daily read on this Forum?
regards thoramay.
amoringello
Posted 14/11/2010 - 16:49 Link
I think there was discussion of all new lenses being SDM-only, but I would have to assume cameras will need to support older drive motors for quite some time.
Pentax does not advertise all the new lenses that they have available (for good reason ) ... they advertise about the Millions of existing lenses you can use. Would be counter productive to cut them out of the picture - so to speak.
