K5 or K5II?
If you want to know why, take a look at this camparometer.
I will be going from the K-7 (same sensor as K-20) to a K-5IIs.
Try some comparisons against the likes of the Canon 60D I think you will be pleasantly surprised.
Video is probably the greatest difference between the K5 and the K5 II.
I would read this, as it applies to the K5 as well.
If that is enough to get by in video-mode, I would probably just get an okay second-hand K5, and use the difference on glass, or save it instead.
Comparing the K5 to the K5 IIs is a bit different though.
And here you need to know if the lack of the low-pass-filter will matter to you.
As I see it:
'K5 -> K5 II' - mainly tech upgrade, and the video mode.
'K5 -> K5 IIs' - same upgrades as to the K5 II, but this time also some noticable IQ improvement.
If you are comming from the K20D I think you would be more then happy with the K5, probably more so if you can get a bargain on a second hand one
If possible; and in your position I'd budget for the MkII and buy the K5 MkONE. Plus a shiny peice of glass!!
Digital:
Flash:
Film:
The only documented changes are to the Autofocus system and the rear screen. Certainly that's what Pentax's press releases & websites have stated and all the previews reported.
I should stop posting stuff so late, just ends up getting confused.
Probably my own keen interest in the GH3 for video that got me a bit carried away.
Looking closer back on some of my notes, it seems that the K-5II still have the same limitations as the make one had when it comes to video.
If anything that means whatever you did read on the link I gave should be valid.
@elfer, thanks for correcting me on that one.
Simply because the previews, and most of the first look stuff just ends up testing what the 'press releases' already stated, ignoring all the rest.
Shame really, as it doesn't paint the whole picture.
My k-5 doesn't hunt much at gigs but i think the lower light capability may make a little difference not a lot but enough for me to justify buying it
I think the small price difference between the k-5 and the mkii I wouldn't risk the thought of what if??? So go for mkii...
Concert photography
If the comparison is between secondhand K-5 at, say, £450 and a new II at £800 however, I'd have to seriously consider the older version.
For me then, the real choice is between a secondhand K-5 at £450 at a IIs at £950. But £500 does seem rather a large premium to pay to lose the AA filter (and get a two-year warranty, I know, I know, but I'm trying to convice myself to spend less!)
Interestingly they've gone out of their way to deliberatley get moire patterns; they got it on the K5, but it is worse on the IIs.
The other Forum has a K5IIs for testing, and the intial comparison shots against a K5 look really good, in favour of the IIs.
However the 2nd comparison of the plastic "pLay it safe" sign is comparable to the differences I've seen elsewbhere and trust that one more
Warwickshire
I don't know whether to go for the K5 or K5II, it seems to me that the only difference is the low light focusing capability. I am corrct in that or are there more advantages?
Also, as I am upgrading from K20 would I notice the difference between a K5 and K5II?
Andy
