K5-lls overexposure
Posted 17/06/2013 - 23:35
Mine used to overexpose too when I first got it, but as soon as I updated to the latest firmware the issue disappeared completely and has never happened since. Pentax did ship out a couple of firmware updates in pretty quick succession when the IIs was launched, so maybe there was a software problem? I am running version 1.03 now.
Posted 17/06/2013 - 23:39
I deleted them as I went along unfortunately so I'll have to see if it does it again in the next few days so I can post some. It's a bit sporadic - can go for a few weeks without doing it and then it does it again. It's a bit odd to say the least. Basically it's as I said - not just iffy but so overexposed that sometimes you can barely make out any part of the picture.
Posted 17/06/2013 - 23:43
Just checked and it's version 1.3 - SRS updated it when they had it back to sort the locking up problem.
Posted 18/06/2013 - 13:02
Also, I just noticed that the version 1.03 update does list a correction for an exposure issue, although it states this was just when using AA batteries, I suspect it could have been a wider problem.
Posted 24/07/2013 - 15:41
I experienced the same thing over the weekend with my lls whilst using AA batteries. Having checked the firmware version it shows v1.04 so this shouldn't be happening?
Posted 24/07/2013 - 18:45
Just to clarify, Sue, has the problem of over-exposure happened with different lenses?
Philip
Philip
Posted 24/07/2013 - 21:20
I am trying to remember exactly which lens/lenses have been involved. The first time it happened I think it must have been with the 55-300mm on the next occasion it could have been the Sigma 50-150mm . Since posting this thread back in June it has'nt happened again except on a couple of occasions when using my Sigma 120 -400mm where it also did'nt always lock af - as this lens worked perfectly with my K-30 [and other previous models] I put this down to some incompatability between lens and camera rather than a camera problem. Have had another 3 or 4 lock ups which has been annoying!
Posted 24/07/2013 - 21:47
Still no more issues with my K-5iis since updating firmware, it has now taken thousands of shots. I suspect if some are having problems this may be a faulty camera or possibly electrical contact issues between the camera and the lens. I would try cleaning the contacts on both camera and lens first.
Posted 24/07/2013 - 22:48
I remember when the K10D came out, Pentax explained the necessity for using an (expensive) proprietary battery, instead of AAs, arose because the voltage of AAs often fluctuated considerably, causing exposure and other problems.
It seems they should have retained the proprietary batteries.
Posted 25/07/2013 - 02:52
Hi...
I was just on a trip and all of a sudden my K7 started seriously overexposing all of my photos. Two different lenses. I turned it on and off several times. Exposure compensation is at zero, and I tried many different setting combinations and metering modes. It works perfect in Auto mode, but ANY other is completely whited out. And whited out in a very similar fashion. I recently updated my firmware (here in July 2013), but it worked okay for a while before doing this.
Any thoughts? I am not an expert, but I have had my camera for a couple of years now and have never had this problem. I have also shot easily over 10,000 photos with it... In Manual mode I pay attention to the readouts and adjust things accordingly and USED to get good photos... now they are all white!
Any help would be appreciated... I did not necessarily want to start a new thread since this was here, but if I should please let me know.
Thank you!
Thank you!
Posted 25/07/2013 - 07:50
I'd check the image styles and digital filters to make sure one wasn't inadvertently set.
