K5 Auto ISO setting in User 1,2,3,4,&5.
Posted 25/03/2013 - 20:52
Is that the one where you press the ISO and the green button together- takes you back to Auto ISO?
Barrie - Too Old To Die Young
Posted 25/03/2013 - 21:23
Not sure if I'm understanding you correctly, but you can change the auto iso setting in menu, number 3 then move down to iso sensitivity AUTO setting.
Hope this helps
Hope this helps
Posted 26/03/2013 - 09:33
In User 1 it shows Auto ISO 100--12800 and when I go to 3 ISO AUTO setting I can not go below 100 or above 12800.
In User 2 it shows AUTO ISO 80--51200 and when I go to 3 ISO AUTO setting it shows 80--51200 all as I want it.
In User 3 it is as in User 2 as I want it.
In User 4 it is as in Users 2 & 3 as I want it.
In User 5 all is the same OK.
The difference between the Users is only in the White Balance. All are on RAW DNG except 5 which is on Jpeg and fast rapid. All are on P.hyper so that I can alter my AV & TV as I need to.
SO back to the origonal question. Why can't I alter the AUTO ISO to 80--51200 in USER 1?
HELP HELP CHEERS Vic.
Posted 26/03/2013 - 09:38
P.S. I seem to have solved the problem in P with the help of Barrie. Thanks on that one. I'd forgotten that one and couldn't find anything in (THE BOOK)
CHEERS Vic.
CHEERS Vic.
Posted 30/03/2013 - 08:45
Now sorted. Set it in P save it in User then reset P to where you want it. CHEERS Vic.
Kettering Northants
I've tried reading the manual but still no joy.
Once again HELP.
CHEERS Vic.
