K5 and IQ
Posted 16/06/2012 - 11:46 - Helpful Comment
Hi Stan,
You should be able to get decent sharpness with the 55-300mm. But there have been discussions previously about the lack of sharpness with this lens, and certain possible reasons.
I found that i couldn't get a decnt focus, especialy at longer focal lengths, and the reason was because I had a UV filter on. Others have had problems using a CPL filter on it too. So, if you have got a filter on it, take it off and have a go like that and let us know how you get on.
If it's not that, maybe someone else can help you. But I've found that lens pretty sharp on the K-r.
Cheers,
ds
Cheers,
ds
Posted 16/06/2012 - 12:20 - Helpful Comment
I'm getting better results with the 55 - 300 DA on my K5 than on my old KR.
Autofocus is better, metering seems better and the quick focus ring sorts out occasional hunting when at wrong end of range. Curiously, spot AF is less necessary on the K5 than on the KR for wildlife. Spot or centre metering is recommnded with this lens.
My 'Swallowtail in Greece' on the gallery on here is taken with that lens on the K5 which I remain very excited about every time it comes out of the bag! Sad but true
Posted 16/06/2012 - 12:29 - Helpful Comment
It should be razor sharp on the K-5 even at 300mm and crops
aren't usually a problem. The big advantage is the high ISO
400ISO is good and 1600ISO is only slightly more noisy.
Recovery of underexposed shots is excellent.
Personally I would prefer the K-5 to any new lens.
For best results with the 55-300mm it needs to be between
f/8 and f/11. Most poor results with any lens are usually
due to camera shake.
Posted 16/06/2012 - 13:17 - Helpful Comment
I've used the 55-300 on the K20, K7 and K5. It is perfectly sharp on all three. Results from higher ISO on the K20 and K7 will be fine in bright conditions. Noise is much more noticeable in darker scenes and of course you can't tweak exposure as you can with the K5. Personally I'd first concentrate on optimising results with exisiting kit, trying out tripod mounted, cable release, mirror-up on a still subject.
Posted 16/06/2012 - 14:10 - Helpful Comment
If you are using the tripod to get sharp shots then as said use f8 to f11 also use the 2 second self timer to release the shutter. And keep the shutter speed above 500th of a second.
Posted 16/06/2012 - 14:40 - Helpful Comment
And Turn OFF the Shake Reduction ( SR )
Chris
Posted 16/06/2012 - 14:42 - Helpful Comment
Chrism8 wrote:
Any of the remote or delayed release modes turn SR off automatically.snappychappy wrote:
And Turn OFF the Shake Reduction ( SR )If you are using the tripod to get sharp shots then as said use f8 to f11 also use the 2 second self timer to release the shutter. And keep the shutter speed above 500th of a second.
There is no need to change the setting manually for these.
Posted 16/06/2012 - 15:38 - Helpful Comment
It might help to check the focus is right using AF and also
do a few shots using MF.
Posted 16/06/2012 - 16:51 - Helpful Comment
I would second what Neil (darkskies) says about the 55-300 lens. I have had two problems with it, neither of which were the lens at fault:
1. I couldn't get a sharp image - until I removed the UV filter and then hey-presto it was razor-sharp!
2. My K-x was seriously front-focussing so I applied an AF Focus adjustment in the debug menu and all was well. With the K-5, images with this lens are razor-sharp with no AF adjustments.
Also, the AF with the 55-300 is transformed when using it on the K-5 as opposed to the K-x. It hunts very little, is reasonably quick to lock on and produces accurate focus almost every time.
It's a great lens and one of my most used, I think you need to see if you can get it performing as you would expect before upgrading the camera, but if you decide on a K-5 you will not be disappointed.
Posted 16/06/2012 - 17:24
Thanks for all the helpful comments.
I think I was secretly hoping everyone would say Yes get a K5 now Although no one has said absolutely don't (just delay awhile) and Mrs Snap agreed with those comments
I've got a flat test card and one of those triangular things so will try setting something up to test the lens.
I'm still working my way through the manual and have the memory of a gnat so didn't know/forgot SR turned off when using a timer or remote so thanks for that. I very often use the two second timer or a plug-in remote.
I'm away to a wedding in Aberdeen (Wednesday to Monday) so everything is on hold and I will have time to mull over the advice and try it out when I get home.
Northumberland
Out of those the 55-300mm has been the most disappointing. I tend to use a tripod and auto focus most of the time and was wondering could I expect better image quality with a K5 than what I get with the K7. I'm not talking about composition etc just the general overall quality (sharpness).
Or should I just stick with the K7 and buy a new lens or two
Stan
