K5 / KX / K10 which 2 would you keep and why?
Rataegeoff
Posted 01/03/2011 - 11:35 Link
Hello All
I'd really like to hear the views of fellow site members. I started with the K10 and then bought a KX because it allowed me use use higher ISO settings for low light or sports photography, I was pleased with the results and knew that their were some compromises in feel and use vs the K10.
Now along comes the K5 with its faster focusing andlow light performance coupled with the full control options I have in the K10 I wonder if the time has come for a serious look at the K5 (maybe body only)
If I get a K5 I can see I will have a dilemna so if any photographers can give me the benefit of their own experiences I'd be very glad.
For those of you who have one or other of my existing bodies and have bought a K5 did you find the upgrade worthwhile and why?
If you had the three bodies above and could only keep 2 which one would you sell?
I look forward to any thoughts and experiences you can share.
Thanks, Geoff
K10D,KX, DA 18-55, DA 17-70 AL(IF) SDM, DA*50-135, Sigma 70-300, DAL 50-300mm, Kenko 1.5x, loads of SD cards and even more optimism
cabstar
Posted 01/03/2011 - 12:02 Link
sell the k10 & k-x get a k-7 exactlu same body as k-5 so you have that familiarity.
Concert photography
felix
Posted 01/03/2011 - 12:18 Link
I had the K-x and still have the K7 and I find the K-x High ISO better than the K7. But I find the K-x too small for my grip, I sold it off.
if you love high ISO, get the K-r instead
Sell the K10D as the technology is old . . .
But seriously, if you love the K5 get that . . .
Edited by felix: 01/03/2011 - 12:50
Mannesty
Sell the K10D, the other two have far superior low light/high ISO capabilities. A K7 would provide very little improvement as a K10D replacement except for its similarity to the K5.
Looking at your sig., I'd also sell the DA 18-55, DA 17-70, and the Sigma 70-300mm. I'd replace the low FL lenses with a DA*16-50, and maybe even replace the DAL50-300mm with a DA*60-250.
On balance, I'd start replacing your lenses before the bodies.
K10D
Posted 01/03/2011 - 12:33 Link
So dump everything except a KX and start again?
Cheaper to delete your profile.
Edited by K10D: 01/03/2011 - 12:35
cabstar
Posted 01/03/2011 - 12:53 Link
as the owner of 2 matching bodies, this has made vast improvement to my pgotography. in the past ihave used with my gx20 a k110d & a k-x & found it dificult to quickly swap over bodies & work them instantly....
Concert photography
Tyr
Posted 01/03/2011 - 12:55 Link
The K10's sensor narrowly beats the K20D and K-7 sensors for DR so I wouldn't really be tempted by the K-7.
I really like the amount of detail that the K10D captures even though high sensitivity performance is poor. The Samsung CMOS is only better because of the higher resolution masking more noise. For prints I find the K10D is still very good.
I would definitely want to move up to a K-5 but if I had a K-X and a K10D rather than two K10Ds I'd have a hard time choosing which to part with.
The build of the K10D and dual controls is very good to have, although if I used TV or AV mode then you only need one wheel (except for exposure compensation but I use a button press for that anyway on the K10Ds)
I guess what I am saying is sell the K10D and replace it with a K-5. Keep the K-x as a second body, it will work out better than the K10D in the long run.
Posted 01/03/2011 - 13:33 Link
I would always suggest identical bodies - it makes sense to share the ergonomics and also accessories such as batteries, etc.
So K10D and K20D go together, K-x and K-r do and K-7 and K-5 do.
Blythman
Posted 01/03/2011 - 13:38 Link
Maybe olde worlde, but I was equally at home with my MX and SFXn. I used them for two different things.
Alan
Mannesty
Posted 01/03/2011 - 13:47 Link
From the subject line, I had assumed that the OP already had the K5. I didn't read the whole post
Smeggypants
Posted 01/03/2011 - 18:36 Link
I agree, and Mike-P was right
I went out on a shoot on Friday with my K-5 and K20D - I spent a little while wondering why I couldn't set the ISO higher than 6400 to make a particular shot until it dawned on me I was using the K20D
Unlocker
Posted 01/03/2011 - 21:09 Link
Identical bodies everytime, decent glass first though!
GDN
Posted 01/03/2011 - 21:12 Link
Any idea where I can pick that lot up cheaply would be much appreciated...
Gary
Pentax K3
My Flickr
sterretje
Posted 01/03/2011 - 21:39 Link
I bought a K10D 2 years ago, next a refurbed K100D (a year ago) and recently a K5.
I will not let any of them go. Each of them has a function in my setup
K5 for AF primes
K10D (fitted with Katzeye) for M42 and as backup for K5
K100D (fitted with Katzeye) for AF zoom and as backup for K10D
If I really have to let one go (as you asked), it will probably be the K10D. Dual dial is not that important for me, K100D has a slight edge on higher iso and is better suited for my wife. The one thing that I will really miss in the K100D is the easy access to spot, center weight and matrix metering.
But as said, I will not let any of them go.
Smeggypants
Posted 01/03/2011 - 22:13 Link
I'm currently getting stuff together to sell to get a 2nd K-5.
I started editing my K-5/K20D shoot just now and the difference in IQ is startling. I thought there was something wrong with the K-5 until I checked an EXIF and discovered the pic was shot with the K20D
