K3II Hotshoe Flash + Wireless
Posted 27/12/2015 - 21:46 Link
Can anyone recommend a hot shoe flash for the K3II that would work as a master for the Pentax AF360 and the AF540 (preferably at the same time)?
Would the AF201 do the trick?
Digital: Pentax K-1 II + Grip, Pentax K3II + Grip, Pentax MX-1.
Lenses: Pentax D-FA 24-70mm 2.8, D-FA 15-30 2.8, D-FA 70-200 2.8*, Pentax 35mm 2.4, 50mm 1.8, 18-135mm WR, 55-300mm HD, Sigma 70-300mm (macro), Tamron 17-50mm F2.8.
Film: Mamiya C330 Medium Format, Pentax Super ME.
McGregNi
Posted 27/12/2015 - 23:57 Link
No, it won't. A pop-up flash would have been good for that ... Assuming you want optical wireless P-TTL triggering then you have to use another full featured flashgun .... Like the AF-360FGZ .
There are a number of third party alternatives that act as wireless triggers, some Metz and Sigma models for example. The 'P-TTL matt.dm' website lists all the features and compatibilities so you can be sure. You may find it more economic to use your AF-360 on the camera as trigger and get a cheaper one that acts as slave only .... The Metz 58AF1 I think does this.
The other approach is a manual system with radio triggers, but without the exposure automation and features like HSS, 2nd curtain sync, range display etc that are part of dedicated system flash.
Edited by McGregNi: 28/12/2015 - 00:02
Dingo
Posted 28/12/2015 - 08:50 Link
Wot he Said
microlight2010
Posted 28/12/2015 - 12:41 Link
Why not use the K-5IIs for taking photos that require triggering your slave flashes, so that you can use the pop-up as a wireless trigger? You already have that, so there wouldn't be any additional outlay.
K-3II - HD DA20-40 Limited, HD DA55-300PLM, SMC DA10-17 Fishy, AF201FG Flashy
Edited by microlight2010: 28/12/2015 - 12:45
McGregNi
Posted 28/12/2015 - 23:05 Link
Now that just seems like too simple a solution ! There must be some glaring flaw with it ...
I know, I know ! .... He is actually wanting to take some beautifully lit, dual off -camera flash shots .... OF his K5IIs
Posted 30/12/2015 - 13:54 Link
How did you guess?
I just building up my studio/event/wedding kit, thinking about using two cameras with the same two off camera flashes.
