K30 Battery Charger issue - Any ideas?
I've had the blinking light issue a number of times. Although the battery may be faulty it could also indicate the battery has been over discharged and the voltage fallen to a point where the charger see's it as faulty.
Try taking the battery in and out of the charger a few times, effectively repeatedly restarting the charging cycle.
Hopefully after a few attempts the charger will have pushed some charge into the battery, you'll see a steady green light and the battery will charge. If not the battery should be covered by warranty, so back to the shop.
My manual (for a K5II) suggests this indicates the battery is faulty, but...
You did leave the battery in for a few minutes each time? (I should have said that :blush
I purchased a K30 about seven months ago and now the battery will not charge. When I place the rechargeable battery that came with the camera on the supplied charger unit (D-BC109) the green light flashes when previously it remained constant while charging and went off when full.
I have tried the following since the issue occurred but neither have worked:
1. Cleaning the battery contact points.
2. Switching off the auto-off function on the camera and leaving it on to completely drain the battery and then trying to charge it.
I am starting to think there is a hardware fault with either the battery or the charger but I am off on holiday in a couple of weeks and do not want to be without my camera.
I was wondering if anyone has come across this issue before or has any suggestions?
Thanks,
Adam.
