K5 battery charger. LED flashing
elfer
Link Posted 28/03/2013 - 11:58
I've a three-month-old K-5ii, with a three-month-old genuine battery.
Yesterday morning I put the battery on charge and the LED started blinking instead of lighting constantly. I tried removing and reinserting it, with the same result each time. The manual tells me it means the battery needs to be replaced.
I tried it back in the camera and it seemed to have no power at all. Fortunately SRS had originally supplied a spare aftermarket battery with the body, and that saw me through the day.
Last night I dug out the receipt and was all set to go to SRS today for a battery swap when I thought I'd try it one last time. And this time it charged as normal.
Has anyone else had this on a K-5/K-5ii/K-5iis? Is it just one of those things that happens with a K-5 charger every now and then? Or is it indeed the sign I have a bad battery?
The only thing I can think of that I did abnormally the night before the problem was to absent-mindedly leave the SD card door open overnight, with the card itself in my pc's card reader. The camera was powered down. I replaced the card before I removed the battery in the morning. Could that somehow have caused a deep discharge?
bforbes
Link Posted 28/03/2013 - 13:40
I tried to use my I10 recently and it would not show any sign of life when switched on. The battery charger light blinked as you described when I inserted the battery but went steady after a while. I put it down to the battery having no power to communicate with the charger until it's charged a bit. I've had no trouble since.
Barrie
Too Old To Die Young
gartmore
Link Posted 28/03/2013 - 13:45
Dirty contacts perhaps?
elfer
Link Posted 28/03/2013 - 13:55
Thanks, Barrie.
That's what I'll think I'll do. Continue using it as normal and see if it re-occurs.
elfer
Link Posted 28/03/2013 - 13:57
Thanks, Ken.
Possibly I suppose. But only 3 months/3,000 activations old and the contacts look like new.
nanhi
Link Posted 03/08/2013 - 18:58
I bought a brand new K-5 with the 18-135 WR Lens from Henrys of Toronto this January.
I put the Pentax battery for charging in the supplied charger. The charger LED started flashing. I cursed Pentax-Ricoh for a bad battery, but then I took a Johnson Q-tip, dipped it in pure hospital rectified spirit and cleaned both the battery and charger contacts.
Presto the LED lights no longer flashed and the battery was fully charged in about 6-7 hours.
I think the battery terminals build up a thin film on contact with polluted air. So it is good to clean the contacts now and then.
