K3 use with remote control
Posted 13/11/2013 - 12:46
I now have an O-RC1 and its made no difference, it still doesn't work
Have contacted SRS and await a call back.
Posted 13/11/2013 - 13:23
My, how odd.
SRS said they would swap the camera by post tomorrow - what excellent service. I reset the camera and started to package it up ready for return. Thought I'd give it one more go. Pressed the shutter remote - still nothing. Pressed the focus button on the O-RC1 - and the lens whirred into action. Another press of the shutter button on the remote and bingo.
Isn't that always the way?
Another phone call to SRS to put the replacement on hold! Thanks to them anyhow for the excellent service that hopefully isn't now required.
PS Checked again with the cheapie ebay remotes but to no avail with those.
Posted 13/11/2013 - 13:30
JAK wrote:
My, how odd.
What's also very odd John is that SRS told me on Monday that they had no K-3's in stock and wouldn't be getting any more until the middle of next week! I had to buy mine from Clifton Cameras instead. I wonder where your replacement on would have been produced from?My, how odd.
Posted 13/11/2013 - 13:35
Hi David,
Stock came in this morning! Earlier than expected....
Chris
Chris
For all things Pentax please visit www.srsmicrosystems.co.uk - anything not listed please email or call!
Follow us on Facebook
Posted 13/11/2013 - 13:37
Perhaps they keep one back for such circumstances or its their demo one. But otherwise, yes, how odd.
Set the camera back up again now and hope it continues to work OK.
Posted 13/11/2013 - 15:10
All this technical stuff is way over my head but!!
I have an old remote which works fine. Not sure what make it is however. Its logo says "wire and wireless-twin1 R3-UT" and have had it for a number of years and didn't cost much from recollection.
Posted 13/11/2013 - 15:39
oldhat wrote:
Excellent and POWERFUL remote made by SECULINE should work fromHi,
many metres away. Best you can buy.
Posted 13/11/2013 - 15:46
Thanks for that info Algi!!
Have found it very effective but as it was a third party one and cost about £15 from a Jessops sale a few years ago, I thought it was just a bog standard one.
Oldhat
Oldhat
Posted 13/11/2013 - 15:54
Just in case the O-RC1 throws a wobbly too I've programmed a couple of buttons on the TV one-for-all remote that seem to work the K-3 focus and shutter just fine!
Posted 13/11/2013 - 16:07
Chris@SRSWATFORD wrote:
Hi David,
Chris
Thanks Chris for the help this morning ... the replacement was already for sending before I could get back to you to say it wasn't needed after all. I'd even got notification from Parcel Force regarding collection - what's the betting they still turn up? Hi David,
Chris
It was all very quirky but at least if others have the same issue they may read this thread and find what they need.
Quite why the ORC-1 works OK but not the cheap ones is a mystery. I presume they don't use a frequency in the way an RF remote would work but maybe the signal they create is somehow similarly out of range.
There are possibly better non Pentax remotes around which would work the K-3 fine for as I said earlier, I've got the TV remote communicating!
Posted 14/11/2013 - 12:46
They just did!what's the betting they still turn up?
Posted 14/11/2013 - 18:20
I have never had much luck with remotes on either my K-x or K-5. Have tried a few of the Chinese cheapies, of which only one worked on my K-x for a short time. I bought the official Pentax WR remote, which again only worked for a short time, but then realised the unit was faulty as the transmitter was permanently on(checked by viewing the led with a compact camera).
Luckily, my current phone has an IR transmitter, and works superbly as a remote with a free remote app from the Play store.
Pentax K-3, Pentax K-5.
Sigma 8-16mm f/4.5-5.6, Sigma 17-50mm f/2.8, Tamron 70-200mm f/2.8
Pentax DA 18-55mm f/3.5-5.6 WR, Pentax DA 55-300mm f/4.0-5.8
Pentax-A 50mm f/1.7, Pentax DA 50mm f/1.8, Pentax D-FA 100MM f/2.8 Macro WR, Pentax DA*300mm f/4.0
Posted 23/02/2014 - 15:12
I don't know whether this is your issue John but I had a problem with my 'cheapie' remote recently which was solved by replacing the battery.
Mine has a semi-circular top and a CR2025 disc battery that slides out of the bottom. It had been playing up and working only intermittently and I thought it was a problem with the cold temperature that I was generally using it for. It is about a year and a half old and I have not used it that much and I wouldn't have expected the battery to run down if it wasn't being used. But I replaced the battery and it now works fine.
I wonder whether the unit is constantly draining the battery rather than only when in use as I would have expected? Anyway, I am now storing it with the battery out of the unit.
Posted 23/02/2014 - 16:12
I tried different batteries but it made no difference. I suspect it's something to do with the band width or signal quality from the cheap remotes not being precise enough.
Scarborough,
North Yorks.
