K3 questions.
aadixon
Posted 17/01/2014 - 13:27 Link
So, I got my k3 yesterday, and updated the firmware. It's pretty fantastic so far. I'm still learning it, and I literally just figured out what I was going to ask on here (How to use the bracketing feature correctly).
So the little preview button (on the OFF/ON dial) is it just to save the hassle of deleting a photo if it wasn't how you'd like it to be? When doing that I see it saves it as a JPEG, but then gives the option to save it as a RAW after the JPEG is saved. So, does the K3 store the RAW information temporarily or what? Just wondering how it can save RAW if it shot JPEG, or if there is a difference in quality of that RAW file compared to if I shot RAW without the preview function.
-Aaron
Posted 17/01/2014 - 14:21 - Helpful Comment Link
The RAW data is still in the buffer and can therefore be saved at that time. It is the same as if you shot RAW and gives JPEG shooters the chance to save an occasional shot as RAW.
JAK
Posted 17/01/2014 - 15:17 Link
If you just do a preview the image isn't automatically saved at all - it's for testing your settings, only you get the option to save it which is sometimes handy - imagine only having a preview image that was unrepeatable but couldn't be saved! It is possible to customize that in the menu options to give an optical preview instead so you can see the depth of field through the viewfinder before taking the shot like some old film cameras used to have.
Edited by JAK: 17/01/2014 - 15:18
aadixon
Posted 18/01/2014 - 06:40 Link
I know it doesn't save until I tell it to. I just wasn't sure what the point of it would be if you're already shooting RAW. As in, if I took a picture I could just redo it if I don't like the way it looks, not needing a preview button. I can see where I'll be very thankful for it at random times I am sure, such as a high shutter speed shot. I have my K3 set to the digital preview. I know it sounds like I'm complaining about the function, but I'm really thankful for it. I'm just making sure I understand how it works and what advantages it has so I use it correctly.
Edited by aadixon: 18/01/2014 - 06:41
ChrisA
Posted 18/01/2014 - 08:36 Link
I've never seen the point of the function. You still use a shutter cycle, so why not just take the picture and delete it if it's no good, and then take another one that is?
Suppose it was a great shot, and then another great shot comes along, but you miss it because you have to save the earlier image first.
It's not as if the size of SD cards is limiting.
TBH I've never seen the point of the optical preview either. By the time it stops down significantly, the viewfinder is so dark and grainy that seeing the DoF accurately is impossible.
Edited by ChrisA: 18/01/2014 - 08:40
Steep
Posted 18/01/2014 - 09:20 Link
The preview on the on/off switch is a 'depth of field' preview. The feature has been around on cameras since the first automatic iris was invented and works by closing down the iris to the f/stop you have set as long as you have it pressed. It's purpose is to let you check that everything you want in focus is in focus before taking the shot.
Algernon
Posted 18/01/2014 - 12:03 Link
DOF preview (optical) is absolutely useless. It was a feature put on for the moaners. They used to complain that cameras such as the ME Super hadn't got it.
You can't even see the parts through the viewfinder that are IN FOCUS never mind the change from in-focus to out-of-focus
It's also unlikely that the small viewfinder image would have the same DOF as the one calculated for say an 8x10 print.
Steep
Posted 18/01/2014 - 12:20 Link
It's only useless if you don't have a use for it. Some examples of use for a dof preview would be in focus stacking or in portraiture where the subject is close to a background or object you don't want highlighted. Granted you need very good lighting to check focus when you've stopped down a lot but still...
Algernon
Posted 18/01/2014 - 12:37 Link
That's fine in theory, but in practise......
http://www.slrgear.com/articles/focus/focus.htm
As this graph shows, manual focusing through the viewfinder was indeed a complete non-starter of an idea.
As I said earlier if you can't see where the point of focus is. you won't see where it goes out of focus. If you could all the people asking for full frame just so that they can have OOF/Bokeh backgrounds could just put the back of the subject at the change point from focus to OOF making the background very blurred...... Just not possible partly because DOF in practise doesn't follow the theory.
Even electronic AF systems struggle to detect a difference at f/5.6 and smaller.
Edited by Algernon: 18/01/2014 - 12:42
CMW
Posted 18/01/2014 - 13:13 Link
The DoF preview may not offer precision, but it is usually enough to give reassurance that the OOF object you have in the foreground of your pic as seen through the viewfinder using a lens's widest aperture will in fact be acceptably focused at the smaller aperture you've selected. It's obviously not of use on every shot, but it's helpful on some.
Regards, Christopher
ChristopherWheelerPhotography
Algernon
Posted 18/01/2014 - 13:34 Link
More theory It's heavily documented elsewhere that modern screens are manufactured for brightness and not accurate viewing. They have extra grooves cut into the fresnel rings which can cause false images. Most people concerned about large aperture lenses and better viewing install Canon EE-S screens.
In the darkroom days it was well known that the only accurate method of focusing a negative was by looking at the grain through a grain magnifier.
CMW
Posted 18/01/2014 - 13:55 Link
No, not theory. This is my practice. I find the DoF preview useful, even on screens that are less useful for focusing than those I had on earlier SLRs.
You may want to tell me I'm wrong to do so, but I can at least tell you that I am not talking theoretically.
Edited by CMW: 18/01/2014 - 13:57
Algernon
Posted 18/01/2014 - 14:17 Link
Believe that if you want to
In practise you can't actually tell where a camera is focussed and where it is out of focus either through the viewfinder or on the screen as in this typical 50mm at f/5 shot. That's why most lens tests you see on the web aren't of any use. Each shot is actually focused on a different spot in most of them.
kh1234567890
Posted 18/01/2014 - 17:12 Link
With my superninja powers (and with a little help from the Canon EE-S) I can often tell what is going to be in focus and what isn't. Even if the thing I want in focus is outside the puny central phase detect autofocus area of a DSLR. On a good day I can even judge the depth of field
Post by kh1234567890, on Flickr
Pentax M 50mm f1.4 at probably f1.8 or thereabouts.
Algernon
Posted 18/01/2014 - 17:21 Link
I've got a Canon EE-S screen, but haven't got round to
cutting it down for a K-5 yet.
Looks like RH could do with one in his Canon.......
Took all the trouble to do a 17 shot test with two
expensive 50mm f/1.2 - f/1.4 lenses and was about
5 -10 metres different with the distances as mentioned in
the comments. You can see it on the paving flags.
Sadly most Internet lens tests are like that
http://ricehigh.blogspot.com/2013/01/luxury-50mm-lens-fight-ef-5012l-vs-cz.html
Edited by Algernon: 18/01/2014 - 17:23
