K3 Focusing. Fault or too high expectations.
Posted 03/03/2014 - 12:42
Wow thats some narrow depth of field your working with! I don't shoot birds but I reckon you're expectations may be a little high at 300mm (what's that in old money, 400?)
Strange that you should get front and back focus though. Certainly would seem to eliminate the lens.
Did you allow for wind, bullet drop and curvature of the earth?
Sometimes I'm serious and sometimes not, but I consider sarcasm an artform. Which is it today?
Posted 03/03/2014 - 13:01
I had a similar problem with my DA*300 (from new). I was very disappointed with it and came in for a certain amount of stick on the forum for suggesting my 55-300 produced better results (Frogfish even choking on his breakfast!)
The lens was back-focusing badly but, more importantly, it was jumping randomly in and out of focus and this was not always apparent until viewing a shot.
It went to Johnsons via SRS and the AF motor was found to be at fault and replaced under warranty. Since when it has performed perfectly.
Roger
Roger
Posted 03/03/2014 - 13:17
Dave, do you know anyone who could lend you a DA*300 so you could compare each lens? If you have other telephoto lenses, are these hit and miss as well?
I don't own the DA* 300, but I have not had any issues with the DA* 200, or the FA* 80 -200 with my K3.
Perhaps the DA*300 needs servicing?
Fletcher8.
Posted 03/03/2014 - 15:25
Good idea Gareth. NeilP is a friend on here and lives nearby and he has one and now a K3. Will have to get together with him.
... and Roger, yes maybe it should be sent back for a check over. It is well used and coming up to two years old. Sounds like a very similar fault to mine, except when it is correct which is still quite a lot, the quality is second to none.
Posted 03/03/2014 - 15:39
Dave, forgot to state that image 1 is superb. when the DA* hits the mark focus wise it looks like a very nice lens.
I think i need to start saving my pennies and lot of them.
Fletcher8.
Posted 03/03/2014 - 19:48
It certainly is a cracking lens Gareth - check out the ones that are in focus in my gallery!
Posted 03/03/2014 - 21:50
Hi Dave
I haven't noticed any focus issues with my K-3 yet, although I've yet to test it on a wildlife shoot. My old K-5 Mk1 used to behave as you describe, although funnily enough it was with the 17-70, not with my telephoto lenses and it was unerringly accurate on my Siggy 150-500!
That first Crossbill shot is indeed superb, but I would get the camera and / or lens checked out if I were you as it seems odd that it is this variable.
Why not send me your DA*300 and I'll check it out for you
Posted 04/03/2014 - 00:18
I would David, just to get some nice Dipper shots, which I'm sure you have around your way
Posted 04/03/2014 - 20:26
Not sure why this would affect focus? It is fine DOF but why would it confirm focus on something clearly out of focus? It demonstrates it is perfectly capable a lot of the time. I think people like David and Alan Wennington are getting higher success rate under similar conditions.
Laindon,Essex
WHen it is right it is stupendous. But it often seems to front or back focus as well as get it spot on. In fact it seems to be in about equal proportions. I doubt the camera is faulty and I have shot a large number with the Tamron 18-250 with few issues. So could it be the DA*300?
This is the scenario. Mainly shooting furry birds in good light with more high contrast adjacent. I could see it missing focus in these difficult conditions but I am using centre spot focusing (back button focus) and do not press the shutter till I get the focus confirmation bleep and I can visually see the focus point on the bird's head or body.So to summarise:-
With DA*300 (calibrated) it misses focus a lot in AFS mode centre spot focus despite positive confirmation. Is this possible?
We can eliminate camera shake/movement due to shutter speeds, tripod, or the static object nearby being sharp.
Examples below:-
1. In focus
2. Back focus
3. Front focus
Any thoughts welcome,
Dave
