K3 does not recognise focal lengths below 10mm
Posted 02/04/2014 - 07:56
It's simply a matter of camera manufacturers continuing not to recognise the existence of third party lens manufacturers. Pentax have never made anything below 10mm so they don't admit to the existence of such lenses. It's a shame but sort of understandable from their point of view.
Why does that stop you from using DXO (I'm not familiar with it myself)? Perhaps if you manually alter the EXIF?
Posted 02/04/2014 - 08:03
Personally I don't see it as understandable. They should make their camera work with whatever lenses are available in their mount. Let's say they took this a step further and somehow stopped their cameras from recognising any third-party lenses (the sort of thing Apple would do). How many people would continue buying their cameras? I certainly wouldn't, and I'm sure a lot of other people feel the same way.
Posted 02/04/2014 - 08:26
Jonathan, I can understand your frustration, but the 8mm - 16mm lens you have is a made by Sigma not Pentax.
Do you really think Pentax R&D will test every third party lens with new camera body? No camera manufacturer wants you to buy third party glass, it just does not make business sense.
In relation to DxO software not being able to read the correct Exif info, that is a pain. I guess compromises have to be made sometimes when you buy third party kit, but at least you have the option to do so. As Pentax don't make a 8mm - 16mm and Sigma do you get half of what you want which is better than nothing.
Have you thought about a tilt and shift lens? It might be better suited to the type of photography images you want to take?
At least with the Sigma 8mm - 16mm you can make adjustments in photoshop manually, although it can be very time consuming.
Fletcher8.
Posted 02/04/2014 - 08:32
Karel, thanks for your post about ExifTool/ExifTool GUI. I was unaware of this software and have just taken a look and downloaded it.
Many Thanks
Many Thanks
Fletcher8.
Posted 02/04/2014 - 08:40
I can change the exif in PhotoMe, but it's a pain, as I can only do one image at a time. I know batch-editing is possible, but I need to look at each file individually to see if it was taken below 10mm.
As far as I am aware, enabling the camera to read focal length is a fixed function, which means it has been deliberately crippled not to read anything below 10mm. While trying to sell your own lenses is perfectly understandable, the best way to stop people buying the Sigma 8-16mm is to produce a comparable lens, not deliberately make it difficult to use the only existing lens of this focal length that works on your cameras.
Posted 02/04/2014 - 09:24
It's actually Sigma's fault and applies to all marques. They don't , as I understand it, pay the licence fee so they have to "reverse-engineer" their lenses. This means they end up paying money if they run foul of patent law, as in the case with Nikon recently. It also means that their lenses will not necessarily work fully with new camera bodies. Sometimes they have to re-chipped by Sigma, sometimes they can't be upgraded at all.
Neither Pentax nor any other manufacturer will keep track of Sigma's problems, they have enough of their own. Pentax lenses will report properly to Pentax bodies and they make no claims about lenses from other manufacturers that may or may not do so.
Posted 02/04/2014 - 09:41
If you use ExifTool GUI then one of the menu items is Modify > Exif: LensInfo form MakerNotes. This will copy the relevant values to the right places. And with the GUI you can do it on a whole bunch of files at the same time.Karel, thanks for your post about ExifTool/ExifTool GUI. I was unaware of this software and have just taken a look and downloaded it.
It just goes to show that EXIF is far from being a cross-manufacturer standard
Posted 02/04/2014 - 12:06
Someone on the other forum made a small program that scans your folders and automatically corrects the Exif data for any shots taken with the Sigma 8-16mm.
It did not work "out of the box" for me, and thinking back I believe I had to use a different version of Exiftool and update one of the .dll files, but it works well for me now.
It can be found here:
link
link
Pentax K-3, Pentax K-5.
Sigma 8-16mm f/4.5-5.6, Sigma 17-50mm f/2.8, Tamron 70-200mm f/2.8
Pentax DA 18-55mm f/3.5-5.6 WR, Pentax DA 55-300mm f/4.0-5.8
Pentax-A 50mm f/1.7, Pentax DA 50mm f/1.8, Pentax D-FA 100MM f/2.8 Macro WR, Pentax DA*300mm f/4.0
Posted 02/04/2014 - 13:53
kh1234567890 wrote:
The focal length actually gets recorded correctly in EXIF makernotes. Just needs copying to the right place for braindead DxO to see it. Use ExifTool/ExifTool GUI to fix this.
Handy tool. just downloaded it. Cheers
Posted 02/04/2014 - 16:18
It is a shame that the GUI is not being developed any more - there are still a few bugs in it. ExifTool gets updated all the time with new lenses and other EXIF discoveries. As some other programs also install and use it, it is a good idea to check that you don't have old versions lurking on your PC.Handy tool. just downloaded it. Cheers
I use ExifTool/ExifTool GUI and Geosetter Beta all the time.
Here,
there,
everywhere
It's ridiculous that they can come out with radical new ideas like the selectable AA filter yet don't bother to make sure their camera can recognise the focal length of all available lenses. The Sigma 8-16mm is one of my most used lenses, and below 10mm I can't use DXO's excellent lens-correction profiles (as I couldn't with the K5) because the focal length is not recorded in the exif. Surely a simple firmware upgrade would fix this?
My Website
flickr
G+
Facebook
