K20D set-up for birding
Posted 22/08/2011 - 19:29 - Helpful Comment
you should not be shooting under 1/600th sec, at 400mm as thats rule of thumb but you can go slight slower than that with the sr 250th sec but depands how you handle the lens and keep your breathing steady, i have had sharp shots with a 500mm lens on a k20 at 80/th sec.
also if light permites stop the lens down to around f8.
and keep to using tav mode and auto iso ramb up to 1600 if you have to, a sharp noisey shot is better than a blury shot.
Posted 22/08/2011 - 22:36
Thank you for your very helpful answer pentaxanne! I will try to keep all this in mind the next time I take my Tokina 80-400mm out to encounter the Heron you should not be shooting under 1/600th sec, at 400mm as thats rule of thumb but you can go slight slower than that with the sr 250th sec but depands how you handle the lens and keep your breathing steady, i have had sharp shots with a 500mm lens on a k20 at 80/th sec.
My shots above are handheld. I have always imagined that it would be problematic shooting birds in flight with a tripod:
Posted 22/08/2011 - 22:56
I bought my K20d and sigma 150-500mm for birds and wildlife. The below is spot on.
I have shots taken at 330mm on my sigma 150-500mm at 1/80th that have come out sharp.
lapwing by Neil Phillips, on Flickr
The key is to have a solid base to rest the lens on (in this case a stationary car door) on a bean bag (or jumper in this case!) and to hold the top of the lens to keep it steady. And for the subject to not move!
Further to this for birds in flight 1/500th or 1/600th is probably the minimum, and 1/1000th at least often necessary to stop motion blur.you should not be shooting under 1/600th sec, at 400mm as thats rule of thumb but you can go slight slower than that with the sr 250th sec but depands how you handle the lens and keep your breathing steady, i have had sharp shots with a 500mm lens on a k20 at 80/th sec.
Posted 22/08/2011 - 23:05
good point about bif from neil, and also a good thing to remember keep your panning smooth, and as said if you can use a bean bag to steady you go for it, also a monopod does come in handy,
me and my husband had a go at swifts recently and thats one fast bird i believe the fastest in level flight,
Posted 22/08/2011 - 23:19
Hawks swoop down at approx. 140mph according to our local birds of prey person.
Colin
Edmund Burke (1729 – 1797)
Posted 22/08/2011 - 23:34
Everything has been said above, but I always had difficulties focusing with non pentax lenses on my K20D. Have you tested it on a tripod with landscape to ensure that it is not ff or bf, or AF issues.
I know the disaapointment when you have got your kit all worked out, cost a lot of money, and just cant get the quality of picture you expect.
Really depressing.
Cheers,
Really depressing.
Cheers,
KR, Pentax 55-300 DAL, Pentax DA 17-55, Pentax 35-80, Generic grip, Generic remote, Nissin Flash. HISTORY - MZ 50, MZ 60, *istDS, KM, K20D, Nikon F60, Nikon F90. Large assortment of Point and shoot film and Digital, Sigma 70-300 APO DG, Samyang 500mm mirror lens, Sigma lenses of all assortments. K20D now sold. Sad to see it go, but makes room for an eventual upgrade to the K5 or the K4?
Posted 23/08/2011 - 00:24
Really depressing.
Cheers,
Really depressing.
Cheers,
The Tokina 80-400mm lens I used for the shots above seems to be quite accurate regarding AF, I don´t believe the lens is the problem.
When using a beanbag or monopod, must the SR be turned off?
Thank you all for your response
Bjørn
Posted 23/08/2011 - 09:30
I'd leave the SR turned on for everything but a tripod.
With that lens you need at least f/8 at the 400mm end.
I set my apertures in 1/3 stops so I usually try to sneak
f/8 + 2/3rd stop. I normally set the exposure manually
looking at the histogram. 1/250th is usually OK for anything
other than BIF.
Personally I wouldn't bother with BIF with that lens until
I got more used to using it on birds in trees.
other than BIF.
Posted 23/08/2011 - 12:46
I would give birds in flight a wide berth until you've mastered taking them asleep first
Seriously though, I've still not mastered birds in flight and I've been at it for years, you need to know your gear and its capabilities like the back of your hand.
Looking at your images I can only say that you need to get out when the light is really good and then show us the pics, all of these look like they were shot on overcast miserable days, meaning you have to open up the aperture and reduce the DoF which means even more critical focusing, your also dropping your shutter speed and risking camera shake or movement blur (from the subject) in addition your raising the ISO which is going to further degrade the image, add to that the lens may not work at its best at full zoom in poor light, resulting in even poorer contrast than normal.
Basically the problem with these shots is you've pushed your gear far beyond its capabilities under the circumstances, I know because I've done it
Posted 23/08/2011 - 19:46
a peregrine falcon is the fastes animal on the planet recorded by nat geo in stoop doing 250mph, but in level flight they can only manage 40mph, compared to swifts at 70mph.Hawks swoop down at approx. 140mph according to our local birds of prey person.
http://www.rspb.org.uk/advice/expert/previous/fastest.aspx
in 2007 a peregrine was clocked at 242mph but since then one has been clocked at 250mph but cant find it.
http://www.youtube.com/watch?v=j3mTPEuFcWk
Posted 23/08/2011 - 20:41
Thank you all for taking time to give me such great photo-technical advice! It is very helpful for me in the learning process
Algi: I will remember your suggestions about exposure and the Tokina. And yes, I guess I primarily need to get to know the lens. I know that doing capture of BIF must be one of the most difficult endeavors.
Alan: You have pointed out the most problematic aspect of my Heron captures on Sunday, that it was a overcast day late in the afternoon. The next time I will make sure that the light is really good. I also hope I can find a Grey Heron sleeping in a tree
Bjørn
Bjørn
Posted 23/08/2011 - 21:03
If the local farmer has been doing any work in his fields, Herons
very often hang around the field looking for mice etc. at this
time of year.
time of year.
Trondheim,
Norway
My dilemma is that I know that one has to have a high shutter speed for birding (1/2000 or higher some say), at the same time the Tokina needs maybe f8 at 400mm. And then it is difficult to have less than ISO 800.
Could somebody please give me advice on the best way to set up the K20D for birding?
Here are some examples of my photos from yesterday (All at 400mm):
1. 100% crop, 1/250, f5.6, ISO 400
[IMG]http://i812.photobucket.com/albums/zz50/bjolester/HERON_A.jpg[/IMG]
2. 100% crop, 1/250, f8, ISO 800
[IMG]http://i812.photobucket.com/albums/zz50/bjolester/HERON_B.jpg[/IMG]
3. 100% crop, 1/350, f8, ISO 560
[IMG]http://i812.photobucket.com/albums/zz50/bjolester/HERON_C.jpg[/IMG]
4. 100% crop, 1/350, f8, ISO 800
[IMG]http://i812.photobucket.com/albums/zz50/bjolester/HERON_D.jpg[/IMG]
Bjørn
