k110d autofocus problem
Posted 29/04/2007 - 12:39
It may be the lens and not the camera, have you tried different lenses? If the same happens you may need to send the camera for a checkup and repair...
Posted 29/04/2007 - 12:53
Thanks for your suggestion - I only have one lens unfortunately.
I might go to local camera shop and ask to try another lens with it, but not sure how helpful they would be.
Posted 29/04/2007 - 14:56
Depends on the shop, privately owned places will have staff who are generally more helpful and friendly in my experience.
I assume you have the 18-55mm kit lens, so go try out the one they have on display and the 50-200 as well.
I was wondering if anyone knew of a simple fix, or if not someone could give me an idea of how much these things cost to repair.
Symptoms:
- In AF mode lens focuses back and forth a few times and then fails to find focus lock (green hexagon flashes in viewfinder)
- In manual mode the camera works perfectly, INCLUDING the focus indicators! (so the camera knows when it is in focus)
PS using the kit lens and have tried cleaning the lens & camera contacts
Many thanks
