K10D Stop down metering exposure problem
Posted 22/02/2007 - 04:00
I've tried the green button, the DOF preview and metering from that, and various other tricks. The K10D just doesn't like stop-down metering.
I can use match-needle type metering or plain manual if an A lens is set to A, but somehow stopping down doesn't quite work.
I works with the D, and I see no reason it shouldn't work on the K10D. I've used two different focusing screens, same result.
I don't particularly want to buy new 200mm and 45-125 range zooms~
Posted 22/02/2007 - 06:40
How truly unfortunate but a sincere thanks anyway for that test and your reply Arthur. Hopefully Pentax will get this sorted out well before I can afford a K10D. As you know, there is much chatter about this everywhere on the Web so I am sure Pentax is all over it. In the meantime that does little for you and your fine manual lenses Arthur. I've tried the green button, the DOF preview and metering from that, and various other tricks. The K10D just doesn't like stop-down metering.
I'm sorry justgetoutandride I must be dense but after reading your reply several times I just don't understand your answer in relation to my post. What I was trying to ask was; if you are experiencing exposure errors, does setting the shutter speed manually using the DOF preview button and the Tv wheel work any better than using the green button?
I don't know if you realize AJ that you will not get good results using an M lens with the camera set to Av mode unless you want to shoot with the lens wide open.
Interesting opinions about abandoning M lenses now that some have upgraded to the K10D. That is valid if you value the camera body more than the lens but I for one will not be upgrading if the K10D makes my lovely M primes useless. But hey, that's me. I'm different.
Anxiously awaiting for a flurry of M lenses on Ebay
Drew
Posted 22/02/2007 - 07:08
Drew
I'm new to all this so take anything I say with a pinch of salt. I have a 50mm M lens I was trying with the k10, after reading this thread I experimented to see how to best use it. My expereince is that using it in manual mode, with the DoF/preview switch and the front wheel allows you to change the exposure 'on the fly'. This seems to me to be the best way to use a manual lens on the k10.I'm sorry justgetoutandride I must be dense but after reading your reply several times I just don't understand your answer in relation to my post. What I was trying to ask was; if you are experiencing exposure errors, does setting the shutter speed manually using the DOF preview button and the Tv wheel work any better than using the green button?
Drew
I put in the difference between manual and Av for comparison. Sorry if i confused you, i don't always know what I'm talking about either.
Please call me aj,
Posted 22/02/2007 - 07:41
I've jsut been experimenting with my k10 and a 50mm M lens.
In manual mode, you can turn the shutter preview switch (around the on/off switch) to do the same thing, i.e. the exposcomp 'lines' are displayed and the front wheel is used to set shutter speed.
This is true.I've jsut been experimenting with my k10 and a 50mm M lens.
But have you also done this with an A lens, first in non-A mode as above, and then cross checked the exposure/aperture combination that the camera says is correctly exposed, with the exposure it chooses for the same aperture (selected with the rear e-dial) with the lens in A mode? All with the camera in Manual.
My experience is that they are not the same.
And if they're different, they can't both be right.
Posted 22/02/2007 - 08:03
Are they widely apart or just a half stop or so?
Was the camera on a tripod with a constant light source as the target and exactly the same field of view?
I only ask because the slightest change in position with an average scene can cause differences in the exposure indicated. To be a proper test needs a description of the method used, just like we did in Physics back in school!
Posted 22/02/2007 - 10:58
This is true.
But have you also done this with an A lens....
No, 'cos I don't have one. only recently got the k10 and kit lenses and the 50mm M from my son. This is true.
Sorry.
Please call me aj,
Posted 05/03/2007 - 15:43
Kinda puts into perspective the now rather hollow-sounding, arm waving comments from the whingers who bang on and on and on and on about how unjustifiable it is that C/N are in the ascendant while Pentax historically have been in the relative doldrums.
Examples please. Or is this just a hollow-sounding, arm waving comment from a whinger who bangs on and on and on and on....? matsoberg wrote:
As said above, What were Pentax thinking? They must have recognized this as the green button is there....
I only have manual SMC lenses (six) exept for the seventh, thats the 35/2 and I must say I feel cheated on, as the promo told that whatever K-mount lens there is, it would compatible with the camera. Wrong exposure in a camera made in 2006?
Exactly.As said above, What were Pentax thinking? They must have recognized this as the green button is there....
It's all the salesmen's fault, of course... why wouldn't we be over the moon about this groovy slimming 'let's digitally stretch the picture, yes the punters will think that's cool' function instead of a metering system that ****ing works?
Sorry. Do I sound like I'm ranting?
Yes. I suspect that you, and the others who claim to have a problem, are doing something silly.It's all the salesmen's fault, of course... why wouldn't we be over the moon about this groovy slimming 'let's digitally stretch the picture, yes the punters will think that's cool' function instead of a metering system that ****ing works?
Posted 05/03/2007 - 16:56
Well I suppose it's understandable that if you've prejudged me as a whinger, you aren't that interested in reading the example I've posted, but let me draw your attention to it.Examples please. Or is this just a hollow-sounding, arm waving comment from a whinger who bangs on and on and on and on....?
https://www.pentaxuser.com/forum/viewtopic.php?t=3867
Post number 6.
I'd be the first to accept that I might be doing something wrong, and the most pleased if it turned out to be so.
Posted 05/03/2007 - 17:03
Just a thought. Is the eyepiece covered or uncovered when you're doing these tests? i.e. could it be ambient light coming in through the viewfinder that's confusing the meter?
If you've got the camera tripod mounted, I'm just thinking you may be looking through the finder some of the time, and not at other times...
Dan
Dan
Posted 05/03/2007 - 17:09
It's a valid thought.Just a thought. Is the eyepiece covered or uncovered when you're doing these tests? i.e. could it be ambient light coming in through the viewfinder that's confusing the meter?
But from my first post on this thread:
I was very careful to cover up the viewfinder completely before setting the shutter speed for a given aperture.
I'll run the tests again I think. I'm starting to doubt my own name.... I was very careful to cover up the viewfinder completely before setting the shutter speed for a given aperture.
But I'll happily eat a Desperate Dan-sized slice of humble pie if this all turns out to be finger trouble...
Posted 05/03/2007 - 17:18
Fair enough - hadn't re-read the whole thread...
Dan
Dan
Posted 05/03/2007 - 17:54
I got told off by George for using my Weston Master V meter; he said there was a very good 'Spot Meter' built into the K10D but if the Weston WORKS and the Pentax meter DOESN'T on Manual then (when I get the replacement ! ) I will continue to use the Pentax with Weston V and Invercone same as for my Rollei or my Zenith and Pentax SV!
Posted 05/03/2007 - 21:52
There is no reason at all why you shouldn't continue using your Weston + invercone. The difference lies in the measurement of incident light (Weston + cone) versus reflected light (any and all in camera measurement systems). Accurate incident light meter readings will always prevail (IMHO) over any camera system including Pentax, Canon, Nikon, Leice, 'blad et al.
Posted 05/03/2007 - 22:52
The Weston measures the light falling on the subject. The camera's meter measures the light coming through the lens. I know which I prefer to use.There is no reason at all why you shouldn't continue using your Weston + invercone. The difference lies in the measurement of incident light (Weston + cone) versus reflected light (any and all in camera measurement systems). Accurate incident light meter readings will always prevail (IMHO) over any camera system including Pentax, Canon, Nikon, Leice, 'blad et al.
s. wales
...I preselect the aperature ring setting on the lens, then while holding the depth of field preview button I turn the thumbwheel to select the appropriate shutter speed. The exposure compensation reading in the viewfinder acts as an old fashioned "match-needle" indicator to set the correct exposure with +/- exposure compensation if desired....
In Av mode, the preview does nothing but knock of the viewfinder display, the green button doesn't seem to do much as the viewfinder changes iso and shutter speed automatically depending on light levels, so you focus, set apereture on the lense and the rest is auto.
