K10D Compatible Lenses
Posted 11/02/2007 - 14:43
Almost all Pentax lenses, screw fit or bayonet fit, are compatible.
The screw thread (with Adapter K), K series and M series lenses have no A setting on the aperture rings so are used in stop down mode, having activated the appropriate custom function that enables use of the aperture ring.
The A series manual focus lenses will work perfectly, although obviously with manual focus only.
The autofocus lenses are all fine in every respect.
That leaves you with a lot of lenses to choose from. Check out the various previous threads in the lenses section.
Posted 11/02/2007 - 14:46
avoid richoh (rikenon) lenses. A quick search through these forums on "lens stuck" will explain why.
Posted 12/02/2007 - 16:04
I have seen a thread on Russian Penta-Club where were discussed compatibility with Nikon lenses.
Объективы Никон на тушке Пентакс, Миф или реальность?
I see it's possible to use one with Pentax body (in kinda emergency case) but not safely (the lenses cannot be locked but stuck enough). There are two variants: direct connection and through an adapter.
UK
I regret that now and am quite keen to extend my range of lenses.
The problem I have is not knowing what is compatible with the K10D. I know that anything K, KA or KAF compatible should work but I get the impression from stuff I've read that other lenses are also compatible.
So the question is, how do I identify lenses and other optical kit that will work with my cameras?
Thanks for any info.
K20D, K10D, K-m, MZ3, Metz 58-AF1, Optio MX4 & Linux.(No Windows)
(Gone: *istD, ME Super, Super-A)
