K10D battery life
Posted 16/01/2007 - 16:15
Going to see whats available on ebay and see if I can get a back up without spending another £50 on a geniune Pentax.
There is a posting on the amateurphotographer website "batteries for K10D" which makes interesting reading. Apparently there is a compatible KM battery, amongst other things, that offers a useful and cheaper backup battery alternative..Going to see whats available on ebay and see if I can get a back up without spending another £50 on a geniune Pentax.
Any comments.
Graham
Keep up the good work
Graham
I'll think of something someday.
Graham
Posted 17/01/2007 - 21:51
I'm sure I've read somewhere in the manual (too lazy to try to find it now) that when connecting the K10D to the PC you should use the AC adaptor to supplement power. If I'm right it would indicate that you haven't got a problem ChrisA.
Posted 11/02/2007 - 14:48
Haven't been counting shots this charge, but I noticed just now that the battery indicator went from indicating full, to indicating half-full. This wasn't unexpected since it's been a week or more since it was charged.
What was unexpected was that two shots and about a minute later it went from half-full to indicating empty.
Anyone else noticed this?
Posted 11/02/2007 - 16:21
Yup - I've def had this problem. Been trying these first few weeks to let the batts fully drain before recharging as I do with a new mobile phone battery. The indicator on mine has barely shown the half power indicator before shutting the camera down no more than 5 shots later. It'll power back up very briefly and allow another 2 shots before being totally dead...Haven't been counting shots this charge, but I noticed just now that the battery indicator went from indicating full, to indicating half-full. This wasn't unexpected since it's been a week or more since it was charged.
Annoying... and possibly leaning me towards buying another (3rd) spare battery to keep in the camera bag.
Will
Spirit_of_will
My Flickr
My Flickr
Posted 12/02/2007 - 13:46
Yes, same thing happened to me too, no pre warning of power bars going down,
exactly same circumstances one minute we had power, next it was dead.
Hopefully, now I have spare and will rotate them, they will work better or perhaps it is an issue with the warning bar software?
Posted 12/02/2007 - 18:22
I'm just wondering what will happen to a K10D + grip + 2 x batteries. Will there be any indication when the first battery is depleted and the second one is put into use?
I hope there will be some indication, it'd be stupid to have 2 batteries and only get the 'camera dead' indicator when both need recharging. I for one would not be best pleased if that's the case.
I have this combination but I'm still on my first charge with no indication as yet that any battery is exhausted. I've taken only 250+ shots, not many I know, but I don't get time to use it much yet 'cause I'm only semi-retired . . . and working harder than ever
Posted 12/02/2007 - 18:31
I have this set-up but luckily have always had the camera set up to drain the grip battery first. If I remember right (I could be sooo wrong here ) I've had the battery depleted crop up (with no warning), removed the grip battery to charge it and then carried on shooting with just the battery in the body. I haven't tried it set up to drain both equally for exactly the reason you state...I'm just wondering what will happen to a K10D + grip + 2 x batteries. Will there be any indication when the first battery is depleted and the second one is put into use?
What I do when the second batt is charged again fully is swap that with the body battery so the one in the body always has the most charge...
Will
Spirit_of_will
My Flickr
My Flickr
Posted 12/02/2007 - 18:36
Will,
That behaviour is odd because the manual states that both batteries are checked for state of charge irrespective of the setting you mention. I too have mine set to use the grip battery first. If it does behave as you suggest, that'll do for me.
Time (and more use) will tell.
Posted 12/02/2007 - 21:37
Peter,
I'm not 100% certain, will have to keep an eye on it in the next couple of weeks. It's certainly going from an indicated fully charged state to fully depleted very quickly, i.e. a matter of a few shots - I certainly noticed that when there was just one battery in the camera. I'll have to double check about each one discharging independantly...
Will
Will
Spirit_of_will
My Flickr
My Flickr
Posted 08/05/2009 - 15:20
I was amazed recently by how much juice the lcd takes from the battery.
I got 2100 shots with only occasional viewing from a generic battery and no flash. The battery still had some juice, but I dunno how much. I'd say you could maybe get 2500 out of the battery.
I'd say I normally get 400-450 shots with automatic review and rare use of flash.
Posted 08/05/2009 - 15:30
Did you notice that this topic is over two years old. We've learned a lot in that time.
Posted 08/05/2009 - 16:15
I left my camera plugged in to the USB for a while - my battery was quickly flattened too.
Same here. I was only trying it out anyway but left the camera plugged in for an hour or two by mistake.I left my camera plugged in to the USB for a while - my battery was quickly flattened too.
I find the card reader built in on my machine far more convenient normally so it doesn't matter. But it would seem to be normal (if inconvenient) behaviour.
20 years
The Netherlands
Since here in Holland, and I think also in most of Britain the temperature has only got below freezing on a couple of nights, and most of the time has been around 10 degrees C, it really shouldn't have been cold enough to effect the batteries. If they are affected by those temperatures what will they do in the Himalayas (or even in cosy Winnipeg where I hear it has been -21 )
