K10d Alternate Lenses
Posted 12/02/2008 - 20:51
Hi Daz and welcome to the forum.
The Sigma is definately AF
I have been considering one of these also, and have read good reviews on both, so i would like to know also which one is considered better. I suspect they are pretty much identical to each other.
Camera:|K-7|
Posted 12/02/2008 - 20:53
My goodness, that was a fast response !!
Posted 12/02/2008 - 20:58
Thanks for the welcolm
I have the Digital SLR User mag ( dec 2007 ), it has a small review on both lesnses the Tamron appears to get a slightly better review although both complain about soft images when at full 300mm. I was just wondering if anyone had thier own personal views.
Posted 12/02/2008 - 21:00
Welcome to the forum.
With both lenses you can't go wrong. Exelent value for money.
They are both autofocus. A lot of forum members use the tamron. And are very happy about it. The Sigma also has a APO version who is a bit more expensive. About 160 GBP new. The Tamron is about 104 GBP.
If you go for the Sigma i advise you to go for the APO version. It is worth the extra cash. Both zooms have a good close focus capability (1:2) at 180mm to 300mm. Both zooms are goiing soft from 200 mm to 300mm.
The Tamron is a bit lighter. Both have metal bayonet mounts. Anyway.....,you will be happy with both of them.
good luck,
Martin.
good luck,
Martin.
Posted 12/02/2008 - 21:04
Thanks Martin.
The Sigma APO version has the red trim around the top of the Barrel and the non APO has a yellow trim if i am not mistaken
Camera:|K-7|
Posted 12/02/2008 - 21:06
The lens hood on the Tamron doesn't have a slot for putting your finger in for rotating a circular polarising filter, which is a pain. Otherwise, I like it!
El Dingo - K3-II and K10D
Posted 12/02/2008 - 21:08
I don't think this is right,Clarky But i could be wrong. I was under the impression the old APO version had a yellow rim, and the new silky smooth finish APO one has the red rim. The non Apo version doesn't come with a rim. But again, i won't bet any money on this statement
Martin.
Martin.
Posted 12/02/2008 - 21:10
Welcome to the forum! You're unlikely to find anyone who has both lenses and can therefore do a back-to-back comparison. I have the Tamron and I'm happy enough with it, it's not perfect but it's pretty good for the money. If I had the Sigma I'm sure I'd be happy with that as well.
I think the final choice will come down to what your local camera shop has in stock and/or which you can get the best deal on.
Good luck!
Good luck!
Joining the Q
Posted 12/02/2008 - 21:11
I have been happy with the Sigma 70 -300 APO. The 'macro' facility is quite useful. I try to avoid going beyond 260mm: it does get softer from then on. It was the lens - on a K10D - that I used for the shot that got to the final 10 wildlife entries in the recent Wanderlust competition, so it can get good results. Didn't get a prize, but very happy to have got to the final 10.
Stuart
Stuart
Posted 14/02/2008 - 13:15
out of those two I would go for the Tamron,
if a few extra quid can be found, give consideration to the Sigma APO.
but it does help
but it does help
Posted 14/02/2008 - 13:29
Out of those two I did go for the Tamron.
I was impressed by the reviews, and it's a bit lighter. It was also a lot cheaper at the time I bought one - 60 quid! (from tekno.co.uk - who sadly have now been swallowed up and squashed by Jessops).
Even at a hundred quid it's remarkably good value for money - thanks to the combination of Japanese design and Chinese manufacture.
~Pete
First post after just getting my K10d, I am interested in wildlife and motorsport and would like a zoom lense. Having spent all my money on the camera I have a very limited budget. I have been looking at the following
Sigma 70-300 F4-5.6 DG Macro
Tamron AF 70-300 F4-5.6 DI LD Macro
Both can be bought for around £100, not sure if the Sigma is auto focus ( which I need ).
Does anyone have any personal info on either of the above or can recomend and alternative ?
Nice forum, might have to enter some of the photo comps. once I figure out what all the buttons do !!!!!!
