K10D- Auto EV Compensation, plus Auto ISO in P
Posted 10/01/2007 - 15:52
Actually, just to add to that:
* You can Tv shift to a slower speed, step by step, but you can't then shift back to the Tv/Av combination you were at. (i.e. the K10D allows you to reduce the ISO in Hypershift, but not increase it).
Also worthy of note (compared to the *ist-D) is that if you enable exposure compensation, the Auto ISO still works (on the *ist-D exposure compensation would put you back to the base ISO value).
Posted 10/01/2007 - 20:27
Yes, I too am confused by that AEv compensation setting - I thought I'd wait for a smarty-pants to explain it to me!
Basically it seems to be describing an oxymoron - if it can't get a proper exposure, how on earth could you automtically compensate for anything :
24 years
Sussex,
UK
Listed on page 206 of the manual, and says on the camera "Use auto EV compensation when proper exposure is not obtained". It defaults to Off - i.e. "Does not use auto EV compensation when proper expsr is not obtained" (sic).
Additionally, did you notice that if you use Hypershift in P mode, the ISO setting is fixed at the lowest? For example, if you set ISO Auto 100-1000, and you shift the front e-dial to go into Tv mode, the ISO will always be at ISO100.
If you press the Green button, then the ISO will revert to Auto and will boost itself according to conditions.
This behaviour is different from the *ist-D which will shift ISO even when you enter Tv/Av through Hypershift. But, since we now have the Sv mode, the new behaviour is probably the "correct" one.
But any info on the Auto EV Compensation would be great!
