K10D - SR setting for older lenses
Mannesty
Posted 18/01/2007 - 12:46 Link
Do we set the indicated focal length, or the effective focal length (FL) (indicated FL x 1.5)?
I have assumed that we set the lens's indicated FL, does anybody know for certain. The manual setting of 8 - 800mm is mentioned in the manual but it doesn't state whether or not to use the effective focal length.
Similarly, when using a teleconverter, say a 2x and a 400mm lens, does that also have to be factored in to the choice of setting? I'm guessing it does.
Posted 18/01/2007 - 12:50 Link
I think you assume correctly... twice
Enter the actual focal length (that's what's recorded in the EXIF for zooms, and what shows on the info display).
When using teleconverters you enter the actual focal length again - so, 2x + 400mm = 800mm. It's a right pain with the Pentax AF 1.7x converter
Mongoose
Posted 18/01/2007 - 12:51 Link
I have been setting the lens true focal length since this is what the camera reports when it can read the focal length from the lens.
It seems to work although one thing I've noticed is it seems to be better to over estimate than under. I have a 90mm macro lens and although the manual implies that the best setting would be 85mm I have found that 100mm works better.
If using a TC I assume you'd need to put in the FL of the combination, and this seems to work with my 90mm and 2x converter.
Interesting thought, This means that SR wont work properly using an automated TC unless that TC can change the focal length reported to the camera
Mannesty
Posted 18/01/2007 - 14:40 Link
Thanks gents . . . back to the manual.
Ammonyte
Posted 18/01/2007 - 15:04 Link
Tim the Ammonyte
K10D & sundry toys
