K10D...how to change ISO?
bretbysteve
Posted 17/01/2008 - 22:02 Link
Is the ISO change on the K10D ONLY in the menu, or can you make some button change it with a custom setting?
...I hate these things buried in menus!
cheers Steve.M.
Posted 17/01/2008 - 22:04 Link
It is very accessible in the Fn menu though.
Mannesty
Posted 17/01/2008 - 22:28 Link
It's customiseable within the menu. Both front and back wheels can have their functions reassigned.
beakynet
Posted 17/01/2008 - 23:05 Link
cheers Steve.M.
Sv mode allows you to change ISO from the rear thumb wheel. Works for me when I am happy for the camera to set apature and shutter for me.
Flash: Metz 58, Metz 48
Daniel Bridge
Posted 17/01/2008 - 23:31 Link
If you use Av or Tv mode, you can assign one of the e-dials to control ISO. So for Av, I have the rear dial controlling aperture and the front dial doing ISO.
If I'm in manual mode, I find it easier to quickly switch to Av, adjust the ISO, then switch back to manual, rather than going to the function button.
E-dial functions are controlled from the custom setting menu.
Dan
Daniel Bridge
Posted 17/01/2008 - 23:32 Link
By the way, you won't find mention of this in the Manual, because it was only introduced with the first firmware upgrade.
Dan
Mannesty
Posted 17/01/2008 - 23:38 Link
Dan,
In manual mode, just press the OK button and change the ISO using the front wheel.
Daniel Bridge
Posted 17/01/2008 - 23:41 Link
Ok, Ok!
Dan
Posted 18/01/2008 - 08:41 Link
As mentioned... this is my setup:
* Upgrade to firmware 1.30 (if you haven't already done so)
* Enter the custom settings menu and reassign the wheels for Av (I have rear = Aperture, front = ISO)
* Using the Fn menu, setup Auto ISO and the range.
Now it works like this:
- Auto ISO is in use normally
- Use the front wheel to force the ISO
- Press the Green button to switch back to auto ISO
- Hold down the OK button to see the number of exposures.
The nice thing is that all info is displayed in the viewfinder - Shutter Speed, Aperture, and ISO.
Couldn't live without this feature now
beakynet
Posted 20/01/2008 - 00:53 Link
[quote="Mannesty"]
You can do the same in P mode too! Though yo would then need to go the the Fn menue return to Auto ISO mode.
hefty1
Posted 20/01/2008 - 11:14 Link
Pressing "OK" and the green button together takes you back to auto ISO in modes other than manual (where auto ISO is non-selectable). I think this is only for the later firmware versions though.
Joining the Q
jospan
Posted 09/02/2008 - 23:20 Link
Great tips! These are not mentioned in the manual, right?
Best regards,
John
https://www.flickr.com/photos/jospan
K10D; smc P-FA 50mm F1.4; smc P-DA 18-55mm F3.5-5.6 AL; smc P-F 70-210/4-5.6 ED
hefty1
Posted 10/02/2008 - 00:45 Link
No, you won't find this in the manual. This is because these features (and the wireless flash operation, etc) were introduced in firmware updates after the camera was initially launched. As far as I'm aware the manual has never been updated and so only covers features that were present in version 1.0 of the K10D's firmware.
Joining the Q
