K100D batteries ? What is the "right " type/ make ?
Posted 26/02/2012 - 19:39
I've used CR-V3 rechargable packs, AA Enloops or AA Lithium, and they all worked ok.
Barrie - Too Old To Die Young
Posted 26/02/2012 - 20:25
Thanks Barrie, the CR-V3 we have last around 5 to 10 shots , then they are flat, the NI-MH rechargeable batteries do not always work at all, not even to bring on the screen. Are NI-MH not he right kind ?
Posted 26/02/2012 - 20:34
I use NI-MH in both my cameras, just make sure the body is set to use them.
If I recall corectly there's a bit in one of the menus that lets you select battery type.
Cheers, HG
PPG entries.
PPG entries.
Posted 26/02/2012 - 20:47
I don't think it's battery type. Is it not to select which battery to use first if you have a grip fitted.
Posted 26/02/2012 - 22:30
I've found eneloops to be one of the best, but make sure the charger is a good one, it needs to charge the batteries independently.
Mark
Mark
Posted 26/02/2012 - 22:39
Hello,
I would recommend Rechargeable Sanyo AA Eneloop HR-3UTG-8BP
and a Charger like the MH-C204F (so you can regenerate your batteries)
If instead you do not want to ue rechargeable go with Energiser Lythium
Enjoy
Enjoy
Posted 26/02/2012 - 22:50
I agree about the Enloops being good. as the hold the charge when not in use.
Maybe you need to run some tests with a brand new set of batteries (I would suggest AA Lithium) to start and sort out if the problem is with the camera, the rechargable batteries, or the charger.
p.s. I've said lithium because they are single use so are at full power out of the packing. Maybe someone can say, do Enloops come ready charged?
Posted 26/02/2012 - 22:53
Yes Barrie, Eneloops do come ready charged. I would echo all of the recommendations above for the Sanyo Eneloop batteries - they are brilliant.
Posted 26/02/2012 - 22:56
Bear in mind that the same technology is also used by other manufacturers. I have found Panasonic Evoltas to very good, and 7 Day Shop sell them at very reasonable prices.
Posted 27/02/2012 - 00:52
bforbes wrote:
p.s. ... Maybe someone can say, do Enloops come ready charged?
Yes indeed: www.eneloop.info/home/why-eneloop.html...
In Europe cost 4 for 13 €uro and the pack of 8 for 22€
P
Posted 27/02/2012 - 03:33
We use GP Recyckos. No experience with other makes but they last a reasonable amount of shots (over 250). You can buy the first set with the dedicated charger that allows charging from both 220V as well as from car battery.
One hint:
mark your battery sets so you don't mix them up.
One hint:
Posted 27/02/2012 - 05:15
AndrewH wrote:
I've always used AA Eneloops in my K200 - they retain charge for weeks, and have been reliable for almost 3 years now!
+ 10
K-1 K-01 Q-7
some len
Close to the Edge
Down by the River
some len
Close to the Edge
Down by the River
Posted 27/02/2012 - 18:58
I have an ancient set of rechargeable Energizer 2450 mAh batteries. They last for ages and hold their charge for weeks in my K100.
Best wishes,
Robert Adams
Ernst Hass
Robert Adams
Ernst Hass
Scotland
