K100D Batteries - Finally a solution
Posted 23/08/2009 - 22:29
I'm glad that you finally found the solution.
Oddly enough, that's the same solution I found for my *istD 2 years ago when a set of 4 cost about £25. They are considerably cheaper now.
I don't have any AA powered cameras any more but Sanyo Eneloops are in all of my flashes and anything else that uses AA or AAA batteries.
Posted 24/08/2009 - 17:32
ManixZero wrote:
My partner uses a Panasonic TZ3 Compact (a great little camera) running on a pair of Li-ion cells and it wasn't long before I envied the Li-Ion Cell performance over the NiMH cells.
That is until I bought a set of Eneloop cells.
They have been a revelation in performance! I have now supplemented them with a set of Duracell Active Charge (similar claims)
I have yet to try them but for all those standard NiMH cell users out there - Your frustrations have been addressed!
These latest cells are much better both it terms of shots per charge and charge retention that i can't recommend them strongly enough!
Cheers MZ
Same here. Its reassuring that i can leave my camera fof a while and know it will work when next used. Have 12 now to replace my energiser and fuji rechargeables. Found that thd energiser ones etc lose charge wat too quickly.My partner uses a Panasonic TZ3 Compact (a great little camera) running on a pair of Li-ion cells and it wasn't long before I envied the Li-Ion Cell performance over the NiMH cells.
Cheers MZ
Posted 25/08/2009 - 12:26
I bought my first set of Eneloops last week because of more tales like this
Huntingdonshire
Cheers MZ
AF Lenses: DA15mm Ltd, DA21mm Limited, DA35mmAL, DA50mm f1.8, DA18-55mmWR, FA28-70mm f4AL, DA50-200mmWR,Tamron SP70-200mm f2.8, AF70-300mm LD Di, SP10-24mm, SP90mm Macro.
MF Lenses: SMC-A 50mm, Adaptall 24mm(CW-24), 135mm(03B), 35-70mm(17A) 80-210mm(03A), Micro-Nikkor55mm, Soligor I-S 200mm f2.8 AIS
My Flickr - link
My Photobucket - link
