K10 Focus Calibration
simonjames
Posted 05/08/2011 - 16:24 Link
Hi all,
I was wondering if it is possible to re-calibrate the focussing on the K10?
No equipment list, lifes too short!
JohnX
Posted 05/08/2011 - 16:39 Link
Been a number of posts on this topic, some in the past week or so. Suggest a search?
Short answer is 'yes', using a so-called 'hack' that enables additional options in camera. The adjustment is global, however.
That said, seems people who've used this method find it quick and easy enough to change the 'global' setting for each lens as they use it.
simonjames
Posted 05/08/2011 - 16:44 Link
Have there been posts describing the procedure for this 'hack'?
GregNal
Posted 05/08/2011 - 17:11 Link
Hi, this should be helpful:
link
K-X, Pentax smc DA 18-135mm F3.5-5.6 ED AL (IF) DC WR
Anvh
Posted 05/08/2011 - 17:56 Link
link
Doesn't work with the new firmware use this instead.
http://www.pentax-hack.info/documents/debug.html
Stefan
K10D, K5
AF-540FGZ
simonjames
Posted 10/08/2011 - 23:03 Link
Some useful links, and is it right that the K20 (and all after the K10) have focus calibration as standard in their menus?
davidstorm
Posted 11/08/2011 - 00:11 Link
Simon
K-X does not have it as standard in the menus; you have to force the camera to open a debug menu by hacking it.
Smeggypants
Posted 11/08/2011 - 02:48 Link
There's no 'hack' involved!!
It's done by putting a text file on your SD card and switching the camera on with the card door open.
There's a few threads describing the process on the forum.
Posted 11/08/2011 - 07:59 Link
Regardless of the technicalities or otherwise of the term "hack" we know what people mean - it is a process that was not intended to be user-accessed by the designers. Therefore, users are hacking into it, gaining unauthorised access if you like.
It may be harmless if you know what you're doing, it may not be if you don't.
Anvh
Posted 11/08/2011 - 18:43 Link
The settings in the debug menu are harmless and can all be reseted.
Only when you start to write more codes in the TEXT file, which you can, then things can get dangerous.
Stefan
K10D, K5
AF-540FGZ
Smeggypants
Posted 11/08/2011 - 18:58 Link
^^^^ This is the kind of thing that's both erroneous, scaremongering and is unnecessary.
There is NO hack involved.
Enabling the debug menu to access the AF Adjustment parameters is not dangerous in the slightest.
Posted 11/08/2011 - 21:09 Link
Maybe, but I maintain that you know what people mean.
Smeggypants
Posted 11/08/2011 - 21:20 Link
Most people know what hacking means and are thus put off by the mention of it. This is natural when they have spent many hundreds on a camera and don't want to break it.
This is why I am not happy with the incorrect description of the simple process of enabling an extra AF adjustment parameter as 'hacking'.
It's not a hack by any stretch of the imagination.
Posted 11/08/2011 - 21:23 Link
That's fine, but it's not dissimilar to the corrections made by some to grammar and spelling, maybe....
Smeggypants
Posted 12/08/2011 - 02:12 Link
It's a whole lot dissimilar. The spelling police are just being pedantic, while using the term 'hack' when it isn't a 'hack' is putting people off from calibrating the AF on the camera becuawe of unneccesary and erroneous scaremongering.
When I first got my K10D and lens combo which I bought second hand as a 2nd body to my K20D I had only just got into Digial photography, and actually thought there was something wrong with the K10D/Lens as the pics were so soft. I still think that's why the original owner sold it on.
Then I learned about the debug menu and AF calibration. Situation fixed. I'm used to debug menus, etc as I have a technical background with electronic equipment.
But I also know from experience that many people aren't "Tech Comfortable" at all and we should be encouraging them not frightening them.
