K10 battery grip
dru337
Posted 24/03/2012 - 14:09 Link
Hi guys, I quite like using the portrait format for certain shots but have found the K10d quite awkward to use in this format - so purchased a genuine Pentax second hand battery grip with battery. It came with fitting instructions which I followed to the letter also charging the grip battery. But there are no instructions on using the grip and I thought that the camera could be turned on using the on/off button on the grip but have found in order for the grip to operate I have to switch on the cameras `on` button to operate the features on the battery grip which all appear to work in this setting. I would like to know if this is the correct way to operate the battery grip or am I doing something wrong. Any advice appreciated, thanks, dru.
Darkman
Posted 24/03/2012 - 14:15 - Helpful Comment Link
Yes the camera has to be switched on and the grip as well
felix
Posted 24/03/2012 - 14:16 - Helpful Comment Link
The on/off switch controls the on/off on the grip. You need to switch on the camera and the grip to use the grip.
bettyswolloks
Posted 24/03/2012 - 18:20 - Helpful Comment Link
As said above, yep thats normal.
