K1 ii firmware v1.30 link
Posted 03/03/2022 - 17:28
Really helpful, Gareth, thanks.
Posted 04/03/2022 - 01:07
I've updated firmware many times before no bother. BUT this one isn't working for me. I've tried two cards both 128Gb twice each and formatted them each time as you should. Still no joy. Two batteries both full.
I'll try again tomorrow. Sorry later today.
CHEERS Vic.
CHEERS Vic.
Posted 04/03/2022 - 15:25
I tried again but no joy. Both cards. Each twice. Both fully formatted. Batteries both full.
HELP NEEDED. I've done it all before no bother. Anybody got any ideas?????
CHEERS Vic.
CHEERS Vic.
Posted 07/03/2022 - 11:44
Daft question, where do I find Custum Image? I have looked all through the options and I cannot see it.
Pentax K1-ii and MZ6
ONE UNITED Member
ONE UNITED Member
Posted 07/03/2022 - 11:45
CHEERS Vic.
Try unzipping the .bin file, I did it and it worked.
CHEERS Vic.
ONE UNITED Member
ONE UNITED Member
Posted 07/03/2022 - 13:04
CHEERS Vic.
Are you using slot 1 ? Slot 2 won't work.
CHEERS Vic.
Posted 08/03/2022 - 00:51
Peter. Yes I'm using slot. 1.
John. I've never had to unzip the .bin file before. How do I do that. You got to remember I'm 83 and a little bit UN tech. I manage most things but some I need help with and I don't have a 10 year old to help me.
Looking forward to your instructions.
CHEERS Vic.
CHEERS Vic.
Posted 08/03/2022 - 05:21
CHEERS Vic.
The file you download from the web page is "k1ll_v130.zip"Peter. Yes I'm using slot. 1.
CHEERS Vic.
The file you need to put on the SD card is "fwdc240b.bin"
You access the file by unzipping "k1ll_v130.zip"... right click and select Extract here.
Posted 08/03/2022 - 07:24
Double clicking on the original downloaded file ( k1II_v130.zip ) should also work and produce the .bin file you need to put onto the SD card.
Chris
Posted 10/03/2022 - 00:48
HI FELLAS. Done at last. all updated OK.
CHEERS Vic.
CHEERS Vic.
11 years
Barrybados
Added [SATOBI] to Custom Image.
[Others]
Improved stability for general performance.
* When this update is done, the contents of version 1.21 and earlier will be also updated.
* When this update is done, you will not be able to restore back to version 1.21 or earlier.
https://www.ricoh-imaging.co.jp/english/support/digital/k-1-2.html
