K1 firmware link v1.60
Posted 03/03/2022 - 14:38 - Helpful Comment
Cheers Gareth - not sure how I've survived without SATOBI
Posted 03/03/2022 - 15:42
No probs JR
I quite like how SATOB looks
Posted 05/03/2022 - 00:02
If it looks like MY images from the 70s and 80s then I can certainly do without it!
Posted 09/03/2022 - 00:27
I have tried and tried...and can not get my camera to recognize the update. new SD card...formatted...I hold menu down when starting - and nothing but the normal screen. any suggestions?
Posted 09/03/2022 - 07:04
Ensure you have the right firmware for the camera, that you have extracted the .Bin file onto the SD card and that you must use slot 1 in the camera.
Posted 09/03/2022 - 17:55
yup...did all that...still no luck.
Posted 09/03/2022 - 18:10
It could be that it can't 'read' the card, hence nothing but normal screen, so either the card/contacts or file is the cause. Try reseating any card in slot 1 a few times to clean it in effect, my update went ok with the DCIM folder still there after formatting in camera FWIW. as another in here had problems and removed the dcim folder. Someone could advise another cleaning method perhaps? :
Posted 09/03/2022 - 18:30
I've tried with the bin file inside the DCIM file and I've tried with it outside the DCIM file...neither works.
Posted 09/03/2022 - 19:56
Doesn't it have to be the only file on the card? At the top level?
SteveH!
I prefer 'unconventional'.
Posted 09/03/2022 - 22:14
Not sure if it helps but I take the memory card out of the camera and place in the card reader. On the PC a perform a quick format of the Sd card and make sure there isn't a 'name' attached to the SD card and it's blank.
Once formatted, I place the Bin file onto the formatted SD card.
Whip it out, put back in camera, battery fully charged, press menu and hold in and turn camera on and voila. Works everytime for me.
Posted 09/03/2022 - 23:19
I did more or less the same but using an sd card that I keep just for FW updates and it worked with no problem.Not sure if it helps but I take the memory card out of the camera and place in the card reader. On the PC a perform a quick format of the Sd card and make sure there isn't a 'name' attached to the SD card and it's blank.
Fwiw I did notice that the file name is identical to the previous FW update file !
Posted 09/03/2022 - 23:32
i give up.
Posted 09/03/2022 - 23:37
If you format the memory card there should be no DCIM file.I've tried with the bin file inside the DCIM file and I've tried with it outside the DCIM file...neither works.
Memory card should be totally empty, nothing on it, formatted and the Bin file placed onto the empty SD card.
11 years
Barrybados
Added [SATOBI] to Custom Image.
[Others]
Improved stability for general performance.
* When this update is done, the contents of version 1.55 and earlier will be also updated.
* When this update is done, you will not be able to restore back to version 1.55 or earlier.
https://www.ricoh-imaging.co.jp/english/support/digital/k1.html
