K05 vs K50 and change aperture - manual ring
Jan99
Link Posted 20/09/2017 - 19:43
Hi.
I have an old lens without A-mark, where i can change aperture ring manually.
However I can not set 'manual aperture move allowed' on the K05, but it works on K50.
Customer menu 4 on K05. The parameter is 'grey', can not change.
It must be some parameter blocking the K05, what could it be?
Anyone who knows?
Jan99
Link Posted 20/09/2017 - 20:06
Now I have found it.
Menu Point 27 must be YES to allow aperture change.
Thank's any way.
Jan99
Link Posted 02/10/2017 - 09:16
Problem with fixed aperture f8.0 on 500 mm mirror objektiv.
How can I change exposure time and get the camera to change ISO according to exposure time.
The only way seems to be to manually change ISO.
Anyone got another way to do it?
M or Tv does not give the possibility to change exposure time with the front or back wheel.
bforbes
Link Posted 02/10/2017 - 11:32
Would you not have to set the camera in manual mode and use the green button to obtain an exposure
Barrie
Too Old To Die Young
Link Posted 02/10/2017 - 11:45
As long as using aperture ring is set to permitted, the f/8 fixed aperture is simply open aperture. The camera will work fine in manual and Av. I have a feeling IIRC that whatever other mode is set the camera will still operate only in Av unless set to M.
petrochemist
Link Posted 02/10/2017 - 13:13
This is the case with practically all mirror lenses. You can of course adjust shutter speed with ND filters as well as play with the ISO.
IIRC TAV mode with auto ISO should work OK for getting the settings you want.
.[size=11:].Flickr WPF Panoramio
Link Posted 02/10/2017 - 13:30
When the aperture ring is not set to A, the camera will only operate in Av mode, unless set to M, B or X. So all other modes will only give you Av (aperture priority) regardless of setting TAV or any other auto mode.
