K-x review - essential !!
DonaldM
Posted 29/10/2009 - 06:31 Link
If only it had the weather seals of the K200D, superb review though.
http://www.photographyblog.com/reviews/pentax_kx_review/
TonyM
Posted 29/10/2009 - 07:57 Link
Indeed, although I did find the conclusion on video interesting:
"There's no handy one-touch recording, a reliance on manual focusing, inability to change the aperture or shutter speed during recording, large file sizes that quickly fill your memory cards..."
Shutter speed!!?! Am I missing something
Tony
gartmore
Posted 29/10/2009 - 08:31 Link
Tony, what is your question about shutter speed?
TonyM
Posted 29/10/2009 - 08:36 Link
I might be wrong here (nothing new there!), but for VIDEO isn't the sensor exposed constantly, i.e. there is no shutter speed to adjust?
Tony
golfdiesel
Posted 29/10/2009 - 18:33 Link
Well there is a "shutterspeed" to adjust with video, the same way that most digital compacts do not have a shutter and simply activate the sensor for a certain amount of time.
Tamron Lenses: 28-200
Takumar Lenses: SMC 55 1.8
gartmore
Posted 29/10/2009 - 18:59 Link
There is a shutter speed, the most obvious example of its misuse, IMO, is in TV coverage of football. The 'normal' shutter speed in Europe is 1/50th second but they tend to shoot sport at a higher shutter speed which looks a bit jerky to me so that you can get smoother action replays.
TonyM
Posted 29/10/2009 - 19:02 Link
Clearly I am confused. What's the difference between shutter speed and frame rate then?
Joe S
Posted 29/10/2009 - 19:18 Link
Ken, I think you are mixing things that don't belong together. It's true that the American tv-system is different from Europe - working at 60 vs. 50 herz. This is a matter of how many times a second the image on the tv is being updated - the input must be syncronized to this.
Last time I worked with a serious videocam (pre digital) it had a shutter allright, but unlike slrs it was a rotating thing - so the same principle but a rather different implementation. Also, we were able to adjust aperture while shooting.
Hi. My name is Joel and I'm a travelholic.
Stolen kit: Pentax K7 #3428965 and Pentax FA 43mm #0028350
Blincodave
Posted 29/10/2009 - 20:18 Link
Superb review winning an 'essential' accolade!
Dave
digikid-tv
Posted 29/10/2009 - 21:05 Link
Video is a series of 50 still images per second. CCD cameras work by turning on the sensor for nearly 1/50th sec and charging the sensor to capture the image, then the sensor is turned off and the resulting charge is read out. The pixels are then cleared out and turned back on to capture the next image and the process is repeated 50 times per second.
So although there may not be a shutter control per se as in the case of a stills camera one can consider a video camera to operate with a shutter speed of 1/50th sec by virtue of the system as the imager is turned on and off 50 times per second.
Professional video cameras do in fact have an electronic shutter to shorten the capture period when required, I shall write about this shortly in answer to Gartmore's post about sports coverage.
John
digikid-tv
Posted 29/10/2009 - 21:23 Link
At the risk of hijacking the thread...
This is actually a system where the TV cameras operate natively at 150 fields per second, 3 times the normal broadcast frame rate of 50 fields per sec. The camera output to the live transmission is only basically that of every third field (150/3 =50)thus leading to the poor motion interpolation.
The full frame rate output is however recorded and is available for smoother slow motion replay, there being three times as many fields and therefore motion updates than at the standard rate. One such system in common use is the Sony Supermotion system.
CCD broadcast cameras generally have supplementary electronic shutters to turn the CCD's on and off within the field period. These are normally turned off but may be switched in when it is desired to shorten the capture period. Typical uses are to remove the frame bars seen when shooting CRT computer monitor displays, and to remove strobing effects from lighting running at a different frequency than the camera frame frequency (eg when a European camera operating at 50Hz is used in North America where the mains frequency and therefore lighting flicker is 60Hz).
Another use of electronic shutters has arisen in High Definition TV production (simulating a filmic look) where a 25 frame per sec progressively scanned images are gathered for TV which is a 50 Hz world. The shutter is set to 1/50th sec and is used to expose each frame twice to simulate the 180 degree mechanical shutter of a film (movie) camera, and thus the motion artefacts (flicker and motion judder) of motion film capture.
(European numbers quoted in all above)
Joe S, what type of camera was that with a rotating shutter? It was certainly a pretty rare technology and sounds like a long defunct monster!
John
Joe S
Posted 29/10/2009 - 23:44 Link
John, it seems you know the tech stuff!
Don't ask what camera we were using - it was at university where we had a course to put some of the theories to work. It is some 10 years ago and the camera was already a bit old school then (not enough digital cameras for everybody). And I could be wrong about the shutter - but that's how I remember we where told they worked. More than anything I remeber how hard it was to set up light for moving pictures.
Edited by Joe S: 29/10/2009 - 23:45
