K-m battery life
Posted 27/04/2010 - 21:11
Yes, batteries do discharge if they are not in use. And the higher the capacity the faster they drain.
Posted 27/04/2010 - 21:19
Strange really, I use some cheap 2300 from a supermarket and they seem to hold charge fine in my K200.
Higher capacity ones I've tried seemed to drain, as you#re experiencing, for no reason. It could be a charger thing!
Is your charger rated for the size of battery you're charging?
ould mean a new charger.If not it could mean a new charger.
Cheers, HG
PPG entries.
PPG entries.
Posted 27/04/2010 - 21:25
Charger won't necessarily make *much* difference, unless it's a cheap one. If so, it may charge them according to voltage as opposed to delta peak and that's the easy way to ruin them fast.
2500s that are, say, 12months old and have been regularly used will probably have a headline 1700mAh and selfdischarge within two weeks.
Get some eneloops or hybrios.
Bret
Bret
my pics: link
Posted 27/04/2010 - 21:34
Bret
Thanks everyone for your help, I'll take the batteries out when not in use in the future. Bret, what are eneloops and hybrios?
Bret
Posted 27/04/2010 - 22:18
Google or Amazon the names, you'll see product links. Essentially Low Self-Discharge NiMH-chemistry rechargeables. At least Eneloops have been tested and found to be excellent at keeping charge over long periods of time at room temperature.
Bret
Bret
my pics: link
