K-70 DIY Projects
The first was concieved of when I first used some long glass with it. I did not like having the glass mounted on the tripod with the K-70 body hanging off the back of the glass and otherwide unsupported. My solution was my DIY Pentax K-70 Telephoto Lens Mounting Bar. I like the way it works, especially the stability it provides with long exposures. Later this year I will be using it while experimenting with a Gobe variable neutral density filter.
Pentax DA 18-270mm; Mamiya/Sekor 400mm; Rokinon 650Z 650-1300mm
https://plymouthcolony.net/photos/index.html
