K-7 shake reduction problem
Posted 28/07/2009 - 22:10
1. Are you waiting for the "hand" symbol to appear in the viewfinder?
2. What lens are you using ?
3. Have you tried manually setting the focal length in the SR menu ?
Posted 28/07/2009 - 22:28
I am using one of the kit Pentax lenses 18-55 that comes with the k-7
Yes I did wait for the hand
Not tried setting the focal length, but I shouldnt need to with the Pentax lense on I think.
Posted 28/07/2009 - 22:31
The reason for asking if you can set the S/R manually is that it might tell you if the camera is picking up the focal length from the lens automatically (which you are correct, it should)
Can you post the two pictures on here with exif intact so we can have a peek.
Posted 28/07/2009 - 22:47
I had a look at the sharper image and the exif shows you had S/R on with that too ?
Posted 28/07/2009 - 22:51
yes I did see that on the exif data, but the display on the camera definitely said it was off, Hand with red line through it.
Posted 28/07/2009 - 22:56
I would do a bit more testing to see if you can repeat this.
Posted 28/07/2009 - 23:16
I have loaded a couple more onto Flickr,at http://farm4.static.flickr.com/3489/3766437709_57a2b5e7ae.jpg
Exif now showing on for the blured one and off for the sharper one.
Posted 28/07/2009 - 23:26
On the first pair the sharper one was taken using live view which turns the SR function off I believe.
Posted 29/07/2009 - 00:08
Live view doesn't turn SR off.
Posted 29/07/2009 - 08:41
On Page 134 of the Manual where it says Caution. One of the points mentioned in the list of situations when SR is turned off is "Mirror lock up shooting" I took this to be the same as going into Live view, as Live view effectively takes the mirror out of the way.
Posted 29/07/2009 - 10:57
For some reason (and there are already many threads dedicated to trying to figure out why) SR is not supposed to be employed with tripod work. When you use the camera's self-timer (the only "traditional" way to get mirror lock up) the camera assumes you're using a tripod and so automatically switches off SR.On Page 134 of the Manual where it says Caution. One of the points mentioned in the list of situations when SR is turned off is "Mirror lock up shooting" I took this to be the same as going into Live view, as Live view effectively takes the mirror out of the way.
Although you're right in saying the mirror is out of the way during Live View sessions I would doubt that SR would be disabled in the same fashion. You can check this for yourself though by simply entering LV and then switching SR on and off, if it hasn't been disabled then you should see the image on the screen stabilise. I don't have a K7 (or K20D) of my own to check with unfortunately.
Joining the Q
Posted 29/07/2009 - 11:20
Gwyn posted this in another thread, and it may be worth upgrading your firmware to eliminate some potential causes of problems:
link
link
FILM - Pentax: LX, K2 - 24/2.8, 40/2.8, 50/1.4, 120/2.8, 80-200/4.5, 28-105mm 2.8 macro, AF 280T
DIGITAL - Nikon : D300 - 18-200mm f/3.5-5.6G IF-ED AF-S VR DX
Posted 29/07/2009 - 20:22
Ok I have loaded the 1.01 firmware and I am still getting the same problem/
http://farm4.static.flickr.com/3004/3770010586_3ff31bbdff.jpg
http://farm3.static.flickr.com/2459/3770010574_3e037d0ae3.jpg
first with SR on 2nd with SR off.
Does anyone have any ideas?
