K-7 replacement battery D-LI90
polchraine
Posted 09/09/2010 - 09:45 Link
K10D wrote:
Pentax don't make batteries. The Chinese do. The super cheap versions work very well, so why not use them.
I have just ordered one of these
link
Once its here, I'm going to fit a two cell 2200mA LiPo battery link by cannibalising the insert. I run all of my rechargeable drills on the same things (voltage matched).
I have one original Pentax branded battery, the rest are ten quid third party cells that work fine.
The cheap grip and bigger LiPo will just add a little more cacity.
Cheaper is not always better or even equivalent.
A few years back, I had specified some Lithium based cells for a specific application. We had tested several types and finally settled on two versions.
The company purchasing team found an "equivalent" and were persuaded that it was "identical" and a lot cheaper. They were assembled and whilst being tested a couple of cells ruptured - that required a building of 100 people to be evacuated for 6 hours. Maybe a single failure could occur, but then when it happened a second and third time ...
Would you be prepared to take a risk with your camera and a cheap battery? If it leaks who will you go to? Pentax? They will repair it at a cost. The battery manufacturer? There will be a limited liability clause. The cell maker? A back street in China.
K10D
Posted 09/09/2010 - 10:08 Link
I agree with you Andrew, cheaper is not always better. I have been using rechargeable's since 1980 when I was manufacturing some of the UK's first delta peak nicad chargers.
As I mentioned earlier, there were issues with early batteries from China.
When I bought my first "cheap" battery, I did watch it carefully as it charged and saw how much capacity it accepted as well as the temperature.
All was well and I now use them on my K10, K7, D7 and D700 with no issues.
Smeggypants
Posted 09/09/2010 - 13:22 Link
johnriley wrote:
Nobody should be in any doubt that the 240 V mains supply in the UK is deadly, although it is indeed the current that is the dangerous bit.
My Fraunhauf Induction Coil delivers voltages of around 10,000 V from a 4.5 V battery, and was used in the 1920s and 1930s for medical purposes. The current is very, very low though. In the 1960s the family used in for fun at parties!
As regards the batteries, people are not stupid because they choose a course of action different to our own. They have different opinions, and all opinions are based on their own perceptions and requirements.
OK, maybe stupid was a bit harsh - but none the less we're not talking a 10% or 20% price difference here, it's £55 versus £8 - Even if the £8 batteries performed at 50% of the £55 they would still be a worthwhile purchase IMHO. I use my batteries in rotation and I've never noticed any different between the performance of the Pentax versions and the £8 versions. Maybe I've just been lucky?
Posted 09/09/2010 - 13:34 Link
Batteries can be quite dangerous things. Laptops have been known to burst into flames with faulty batteries, sometimes OEM ones.
My basic viewpoint is that I want the maximum reliability. Therefore, I buy Pentax batteries, and if they fail or if they should become tiny fireballs I would know where to look for compensation.
A cheap battery is from an unknown source. It could be any manufacturer and it could be a good manufacturer who also makes kit for Pentax. Who knows? And that's the problem - it could be a menace that leaks all over the camera electronics and invalidates the warranty as it does so.
As for AA batteries, when I bought them I bought branded ones. Predictable really!
