K-7 replacement battery D-LI90
Posted 08/09/2010 - 12:59
terje-l wrote:
I don't understand this discussion. Here you are spending hundreds of pounds on a camera, then trying to save a few pounds on batteries. Doesn't make sense to me.
Surely the time spent and the risk involved are not worth it.
If you can afford the camera, you can also afford decent batteries.
Me too.
Posted 08/09/2010 - 13:15
Pentax don't make batteries. The Chinese do. The super cheap versions work very well, so why not use them.
I have just ordered one of these
link
Once its here, I'm going to fit a two cell 2200mA LiPo battery link by cannibalising the insert. I run all of my rechargeable drills on the same things (voltage matched).
I have one original Pentax branded battery, the rest are ten quid third party cells that work fine.
The cheap grip and bigger LiPo will just add a little more cacity.
link
Posted 08/09/2010 - 13:30
link
I wonder why all my Pentax ones say 'Made in Japan', Pentax must be telling fibs.
link
Posted 08/09/2010 - 13:55
I've had two original Pentax batteries for the K20D for about 18 months. They still work perfectly. I've also got two cheap ebay batteries (different makes) which were OK at first but after 9 months I could only get about 50 shots out of each compared with probably 500+ off the originals. All charged in the Pentax charger.
Posted 08/09/2010 - 14:32
gartmore wrote:
If Pentax tried to sell you 4xAA batteries for £50 for a K-x, would that make sense? Would you accept that and happily pay that price? terje-l wrote:
Me too.I don't understand this discussion. Here you are spending hundreds of pounds on a camera, then trying to save a few pounds on batteries. Doesn't make sense to me.
Or would you buy Eneloops for less than a tenner?
People understand that point quite well.
Now, make the AAs very slightly larger, put 'em in a plastic case and slap a Pentax sticker on it and it's now worth £60?
We can put 6x AA batteries into a K-7 grip to power it and avoid using any 'official Pentax battery' at all, what would you recommend there?
Posted 08/09/2010 - 19:18
alfpics wrote:
Here's one:
link from 7dayshop. It is the full capacity one unlike the INOV8 which is only 1300mAh or so (and the one available from SRS). I have both and both work fine
Andy
Thanks for all the replies! Interesting how a simple request for advice on what replacement battery to choose can turn into such a debate! Here's one:
Andy
I was going to go for the 7dayshop one but I see they are out of stock - probably as a result of this thread! Note to self... must be quicker!
Used to buy all my film via 7dayshop... I even felt a twinge of nostalgia as I typed in the link, as it's been years since I shopped with them!
Spirit_of_will
My Flickr
My Flickr
Posted 08/09/2010 - 19:21
I usually don't mind spending the extra cash for the real thing. However, all I'm after is a stock of emergency power to tide me through a few days of extended shooting. I cannot recall the last time that I managed to get through the 2 x originals that I already have and therefore spending 60 quid a piece is too steep for me!
Spirit_of_will
My Flickr
My Flickr
Posted 09/09/2010 - 00:09
link
I wonder why all my Pentax ones say 'Made in Japan', Pentax must be telling fibs.Pentax don't make batteries. The Chinese do. The super cheap versions work very well, so why not use them.
link
This is also still an issue though less and less nowadays. You can still get rogue batteries that are low capacity variants.I've had two original Pentax batteries for the K20D for about 18 months. They still work perfectly. I've also got two cheap ebay batteries (different makes) which were OK at first but after 9 months I could only get about 50 shots out of each compared with probably 500+ off the originals. All charged in the Pentax charger.
That in itself may back up the "buy branded" battery line of thought.
Each to their own at the end of the day. The battery/camera combination is no different to brake pads and other car related items where many people use third party replacement parts or comsumables. Even memory crds fall into this area.
Posted 09/09/2010 - 00:23
spirit_of_will wrote:
[quote I was going to go for the 7dayshop one but I see they are out of stock - probably as a result of this thread! Note to self... must be quicker!
I ordered my K7 battery from 7Day Shop a couple of weeks ago and they were out of stock then...
Retired at last - now all that time for photography - you would think: wink:
Posted 09/09/2010 - 00:33
mayday wrote:
I ordered my K7 battery from 7Day Shop a couple of weeks ago and they were out of stock then...[quote I was going to go for the 7dayshop one but I see they are out of stock - probably as a result of this thread! Note to self... must be quicker!
sort of defeats the in body VR though????
Posted 09/09/2010 - 00:50
Smeggypants wrote:
It's too much current that's lethal not voltage. 240V won't hurt you if the current flow is low enough.
This is an extremely dangerous post and should be ignored. 240VAC should be regarded as a lethal voltage.It's too much current that's lethal not voltage. 240V won't hurt you if the current flow is low enough.
Mods - please remove, or at least contact me.
Posted 09/09/2010 - 02:56
I've just seen the price of the Pentax branded battery ... WTF!!!! I don't understand this discussion. Here you are spending hundreds of pounds on a camera, then trying to save a few pounds on batteries. Doesn't make sense to me.
http://www.srsmicrosystems.co.uk/147/Pentax-D-LI50-Rechargeable-Li-ion-Battery.h...
£54.99
That is an absolutely rip off. The 'cheap' batteries I have for my K20D and K10D work absolutely fine and just as good as the branded Pentax batteries that came with the cameras.
If anyone is stupid enough to pay £55 for a battery when you can get them for £7 each then that's their fault. That's not just saving a 'few quid' that's almost an 8x price difference.
Posted 09/09/2010 - 08:52
Nobody should be in any doubt that the 240 V mains supply in the UK is deadly, although it is indeed the current that is the dangerous bit.
My Fraunhauf Induction Coil delivers voltages of around 10,000 V from a 4.5 V battery, and was used in the 1920s and 1930s for medical purposes. The current is very, very low though. In the 1960s the family used in for fun at parties!
As regards the batteries, people are not stupid because they choose a course of action different to our own. They have different opinions, and all opinions are based on their own perceptions and requirements.
Horten,
Norway
Terry
