K-7 Battery Grip Question
Posted 14/10/2010 - 22:45
no just turn camera off and on thats it.
Posted 15/10/2010 - 03:32
I have battery auto-select enabled on my K20D and there's no need to switch the camera on and off. It just uses up both batteries until they are both depleted and the camera dies
Posted 15/10/2010 - 04:01
When I was using a grip I had it setup to use the grip battery first, when this was depleted it would revert to the body battery, I would then remove the grip battery for replacement with a spare (if you have 3 batteries) or recharge it. Once replaced it would automatically revert back to the grip. This eliminates the need to remove the grip and replace the body battery.
You don't need to have the grip turned on until you are ready to utilise it, It will still power the body even when switched off.
Camera:|K-7|
Posted 15/10/2010 - 06:51
Solid logic.When I was using a grip I had it setup to use the grip battery first, when this was depleted it would revert to the body battery, I would then remove the grip battery for replacement with a spare (if you have 3 batteries) or recharge it. Once replaced it would automatically revert back to the grip. This eliminates the need to remove the grip and replace the body battery.
Posted 15/10/2010 - 07:15
I never put a camera in the body, just use the main battery in the grip and when it depletes I replace it with the second battery. That way I never need to take the grip off the camera.
I also leave the grip turned on all the time because it turns off when the main switch is off.
I think it's all down to what suits you.
Posted 15/10/2010 - 16:03
Another like Clarky & Unlocker
Find that leaving the grip switched on depletes the batteries - and that's not just the K7.
Posted 15/10/2010 - 16:31
Same as above. Just have a battery in the grip and nothing in the body.
Posted 15/10/2010 - 17:07
greynolds999 wrote:
Sorry couldn't resist
I never put a camera in the body........
I've never put a camera in my body either - may get some interesting shots so long as you remember to attach the remote releaseI never put a camera in the body........
Posted 16/10/2010 - 00:39
I never turn the grip on. I tried using the grip buttons but I was always accidentally pressing them with my lower hand when the camera was at normal position. When I rotate the camera 90deg to take a portrait aspect I use the body's shutter release.
Posted 16/10/2010 - 10:59
Anybody got one they want to sell
Posted 16/10/2010 - 11:46
if your after a grip i havea non oem one identical to the oem.https://www.pentaxuser.com/forum/topic/k7-and-other-gear-for-sale-22186
Derby ( UK )
I bought a battery grip and spare battery for my K-7 today. I've read both manuals but I'm still slightly confused (which isn't hard lol)
The battery selection option is set to the default 'Auto Select' which is priority is given to the battery with the most remaining power.
The manual says that when the currently selected battery runs out I turn the camera off then on again and the camera will switch to the remaining battery.
I know I don't need to turn the grip on until I want to shoot in portrait.
My (probably daft) question is, once one battery has run out and I have switched the camera on and off do I also need to turn the grip on or does the camera just use the power from the grip battery if the camera battery runs out first.
Regards, Chris.
