K-7 and lens distortion correction
pentaxian450
Posted 14/07/2009 - 18:08 Link
Everybody says the K-7 saves images faster than the k-20d, but that wasn't my experience. Actually, it was way slower than my K20D. This morning, I tried an old Nikon (shame) lens on the K-7, and, lo and behold, the image was saved almost instantly. So, being as smart as Sherlock Holmes, I investigated to try to see what the problem might be. And, since I'm smart, I figured it out. I had "lens distortion correction" and "chromatic aberration correction" set to "on". The dcamera takes a faily long time to process the information, even in RAW, so if you find your K-7 kind of slow to save or display an image, look at those two parameters first. Just in case you're no Sherlock Holmes . I guess now is as good as any other time to go and hide before you start throwing empty beer bottles at me.
beginner
Posted 14/07/2009 - 18:23 Link
But shouldn't you have them switched on?........These settings must be some of the improvements over the K20, so why not use them?......
George Lazarette
Posted 14/07/2009 - 18:57 Link
Personally, I think these might have a place for those shooting JPEG, but none if shooting RAW.
Feature bloat, if you ask me.
Hardgravity
Posted 14/07/2009 - 19:38 Link
Why do you need them, Pentax lenses tend to be the best...
Cheers, HG
PPG entries.
George Lazarette
Posted 14/07/2009 - 19:51 Link
They're there for the Sigma users!
Anvh
Posted 14/07/2009 - 20:07 Link
it only work with Pentax DA lenses so like you said just a feature bloat
Stefan
K10D, K5
AF-540FGZ
Greytop
Posted 14/07/2009 - 20:30 Link
I would of thought a firmware fix could be in order for this because it does slow things down even if you are only shooting RAW.
Regards Huw
flickr
Anvh
Posted 14/07/2009 - 21:17 Link
Does it effect the RAW file at all btw or only the jpg preview photo?
Stefan
K10D, K5
AF-540FGZ
Greytop
Posted 14/07/2009 - 21:19 Link
As far as I can tell the RAW file remains untouched
Regards Huw
flickr
Anvh
Posted 14/07/2009 - 21:27 Link
Then probable the JPG preview image you see with RAW is effected, there are some ways to get that preview image off from the RAW file so that you can compare the two, simply google for that.
Stefan
K10D, K5
AF-540FGZ
Greytop
Posted 14/07/2009 - 21:35 Link
Actually Stefan it's pretty easy to do with the RAW+ button, I just made a comparison between the DNG and Jpeg in CaptureOne 4.8, the difference is quite obvious
Regards Huw
flickr
pentaxian450
Posted 14/07/2009 - 22:49 Link
When the corrections are "on", you can only "machine gun" for five frames before the buffer fills up. And, in video mode, it cuts on your "shooting" time, and it takes forever for the buffer to clear. In RAW mode, it seems to me like it's marking the file so "Pentax Utility 4" will correct the files automatically.
Anvh
Posted 15/07/2009 - 00:05 Link
Ah yes but you said it also does it when you shoot RAW only, it's of course logical it does it to the JPG image with RAW+ but why does it have to do it with only RAW.
So if it does it to the JPG preview in the RAW file you know why it does it.
Stefan
K10D, K5
AF-540FGZ
Greytop
Posted 15/07/2009 - 00:17 Link
Hmmm, you may have a point there
Regards Huw
flickr
chirpy
Posted 15/07/2009 - 09:42 Link
As Yves says, the lens correction information is supposedly stored in the RAW files. If your RAW converter supports the feature then it will use it to correct the image. Apparently the latest Adobe RAW converter included an update to do this, as does the shipped Pentax software (which I'm not impressed with).
