K-7 AF-560 high speed sync off camera
Snappy
Posted 01/05/2011 - 06:17 Link
Anyone have any ideas , I'm wanting to use my pentax flash AF560 off camera at high speed - the manual says to sync with camera etc but as soon as I use the build in flash as the controller the camera will not go above the max sync speed of 1/180 sec....... Only option I can see is getting another flash as the controller??
Posted 01/05/2011 - 08:02 Link
You are correct
Your two choices are to use another AF360/540 as controller or master, or, buy an extension cable (there are some third party ones around).
It's because HS sync requires a high frequency pulsed light to 'pepper' the frame with light as the shutter slit moves across the frame.
Snappy
Posted 01/05/2011 - 08:17 Link
Thanks Matt ! At least I know what I need now!! The flash manual has deceived me !!!
pentaxian450
Posted 01/05/2011 - 11:16 Link
You can also use Sigma or Metz flashes that are compatible with Pentax P-TTL. Those are less expensive, and works properly with the Pentax cameras.
