K-5 IIs sensor cleaning
Posted 12/01/2013 - 12:14
I doubt that it makes any difference as I'm guessing the sensor will still be protected by the IR blocking filter.
Posted 12/01/2013 - 12:19
An interesting question, that's why I bought an Arctic Butterfly. You don't have to touch anything as it attracts the dust with static and I figure if I keep on top of it by cleaning after every shoot I should stay relatively dust free.
Posted 12/01/2013 - 13:07
I've had my K5 for well over a year now, nearer two years, and it's seen regular use with frequent lens changes. I've never had to clean the sensor yet.
I have the sensor cleaning option set, so it gets cleaned of non-sticky contaminants every time it's switched on.
Posted 12/01/2013 - 13:20
I've yet to clean the sensor of my K20d, clearly the built in system is highly effective
Posted 12/01/2013 - 14:05
I thought the k-5 mkii had a new sensor cleaner?
Concert photography
Concert photography
Posted 12/01/2013 - 16:20
I regularly had to clean the sensors of my K10D and K20D. I've had my K-5s for coming up to 2 years and I've never had to clean their sensors. I'm amazed really.
Posted 12/01/2013 - 20:44
Ahoy!
How much would you expect to pay for a pro sensor clean? I happen to use 2 systems (A and K Mounts) and although I normally do my own sensor cleaning as I have both wet and dry kits, I have actually paid for a pro service from Camera Repair Workshop (CRW) who are specialists for multiple formats, but a sensor is a sensor and cleaning is the same whether you go to Calumet, LCE, the manufacturer or other agent, so if you do need a pro clean, you won't find a much nicer company and Dave (the gaffer) is a diamond geezer to boot. Currently they have a 10% off sensor cleaning offer going on (you also pay the cost of postage to/from), but the base cost of an APS-C clean (without discount) is £30.00 (nett £27.00) or £35.00 (£31.50) for full frame. For advice or information, telephone Dave on: 01908 378088.
I hope this may be useful to anyone requiring this type of service and as a repeat customer of their for sensor and lens cleaning, I can recommend them as they provided me with an exemplary service.
Posted 13/01/2013 - 09:16
And another K5 owner who changes lenses a lot and has never had to clean a sensor. I have the "clean at startup" option enabled and it works a treat. And I do run the "detect dust" option. And there never is any..
Paul
Paul
K3ii, DA16-85, DA35mm Limited, FA77mm Limited, 55mm f1.8 K, 135mm f3.5 M, DA300, DA 1.4 HD TC,
DA16-45, Sigma 15mm f2.8. Cosina 100mm f3.5 macro
Posted 13/01/2013 - 16:55
PIRATE wrote:
Ahoy!
It's ridiculously easy to clean the sensor, why would you pay someone to do it?
Ahoy!
Posted 13/01/2013 - 17:19
Yes, I'm fairly sure that sensor cleaning is not given to the most experienced technician to do...:
Posted 13/01/2013 - 21:58
"Ahhh a bit of stubborn muck ....this emery cloth should sort it!"
uk west midlands
Would the cleaning of the K-5 IIs sensor be more complicated now it doent have a filter on the sensor...
