K-5 IIs RAW Problem
Posted 25/04/2013 - 16:24
My K10d has slightly larger DNG files than PEF. Same bird, two formats.
PEF 15,183
DNG 16,596
PEF 15,183
DNG 16,596
Albert in the Canadian Rocky Mountains
K3, M 400/5.6, M 100/4 macro, DA 12-24, DA* 16-50, DA L 55-300
FA 24-90, 1.7X AFA, 1.4X-S
AF 540 FGZ flash
AF 540 FGZ flash
13 years
As for DNG - that spec changes too and older Adobe software will not cope with newer versions too. I do not know which version the K5ii uses but you could have problems with older software that does not support that either.
And a question that I have been unable to get an answer to: Does DNG capture and fully store every piece of information or data that the camera produces and stores in the .PEF format? I have heard comment from a Nikon owner that one or two pieces of data in their format are not available or are truncated in DNG.
Read my comments again ... what I said was that older versions of Adobe software may not be compatible with files created by cameras under the latest DNG specification. New software will continue to read old format files.
Exactly the same happens with MSWord, Excel and many others. Create a file in the 2010 or 2013 version and try to read it in the 2007 version - it will fail. Take a file written under the 2007 version and 2010 will read it.
Check the release of the DNG specification, there have been several over the years.
