K-5 HDMI Cable
dangie
Posted 05/02/2013 - 13:30 Link
Very quick question.
So I don't order the wrong one, which type of HDMI cable do I need to connect a K-5 to my television HDMI inlet. I've seen 'Mini' & 'Micro' leads. All a bit confusing for an old 'un like me. Thank you.
6th Year Apprentice Pensioner
col55555ine
Posted 05/02/2013 - 13:47 Link
k-5 IIs, Pentax 60-250, 17-70, 100macro WR, 50mm F2,
AF50 F1.4, Siggy 10-20, Siggy 100-300 F4, ..Pentax Af 160 ring flash
Edited by col55555ine: 05/02/2013 - 13:53
dangie
Posted 05/02/2013 - 16:32 Link
Thank you. Would this from Amazon be the same?
http://www.amazon.co.uk/version-Connecting-Devices-connector-Camcorder/dp/B003ZY...=tag_stp_s2_edpp_url
col55555ine
Posted 05/02/2013 - 17:02 Link
that looks right, type C ...
when you recieve the cable it should be same size as your port, if it isnt dont force
it..
Type C A Mini connector defined in the HDMI 1.3 specification, it is intended for portable devices. It is smaller than the type A plug connector (10.42 mm × 2.42 mm) but has the same 19-pin configuration.
The differences are that all positive signals of the differential pairs are swapped with their corresponding shield, the DDC/CEC Ground is assigned to pin 13 instead of pin 17, the CEC is assigned to pin 14 instead of pin 13, and the reserved pin is 17 instead of pin 14.
The type C Mini connector can be connected to a type A connector using a type A-to-type C cable
Edited by col55555ine: 05/02/2013 - 17:09
